Threads: 63
Thanks Given: 410
Have a look around the forum matey, quite a bit written on this subject
Thanks Given: 188
23
I had the same thing on my old renault kangoo it was the resistor bank attached to the blower. They are protected by a couple of thermal fuses and the one for the lower speeds has failed. I unclipped mine and soldered a new fuse in brought from maplin for 10p I think but you probably can get a new part. Im just a skin flint by nature.
Are we there yet?????
Threads: 32
Thanks Given: 13
24-09-2012, 09:51 PM
(This post was last modified: 24-09-2012, 09:52 PM by tucker.)
Yeah it is the resistor pack that is faulty.
The resistors are 6 or 7 quid each but you have to tinker and solder them in. You can buy a new resistor pack off ebay for about £15 to £20.
I just replaced mine for a second time the other week.
The following 1 user says Thank You to tucker for this post:1 user says Thank You to tucker for this post
• Merlecollins
Threads: 32
Thanks Given: 24
It's below the glovebox.
Unclip the carpet trim that goes from the bottom of the dash to the top of the footwell and you will see it.
The following 1 user says Thank You to Coco for this post:1 user says Thank You to Coco for this post
• Merlecollins
Threads: 51
Thanks Given: 23
My Wife's Micra used to suffer with this problem. You could solder a piece of wire across the fusible links but.... it used to get hot enough to desolder or blow another part of the resistor. After having repaired it a couple of times I took the fan out and found it was quite stiff to move. The other symptom was that it wouldn't work unless you put it on full power then switched it down to the appropriate speed. I blew out the carbon dust from the brushes, cleaned the commutator and oiled the bearings. Works like a new one now!
Malc
Stupid computer!
