Threads: 41
Thanks Received: 31 in 28 posts
Thanks Given: 16
On my way to work this morning the fuel light came on, so after about 25 miles I pulled in for some diesel. The needle on the fuel gauge was still above the red line but, without brimming it, I managed to get 62 litres in.
An exceptional feat as the car only has a 60 litre tank!!! :brickwall::censored::twisted:
Threads: 63
Thanks Given: 410
Must have been running on vapour.....
Threads: 96
Thanks Received: 448 in 375 posts
Thanks Given: 709
Heard it could be something to do with colder temperature affecting density of fuel.....or magic.lol.
Former 2011 Mk3 XTR owner
alut:
Threads: 41
Thanks Given: 16
The fuel light had only been on for about 25 miles so with that, the number of miles I had covered and the position of the needle on the gauge it should've taken 57-58 litres.
Threads: 9
Thanks Received: 7 in 6 posts
Thanks Given: 2
I've always had my suspicions that petrol stations don't give you a genuine litre... Alternatively your tank could have been empty and even the fuel lines were empty (avg 1/2 gallon in them) which would say you have a fault fuel gauge... I don't know.
If it aint broke don't fix it... if it is broke, who gives a rats ass?
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
Talos is correct.
It is down to Trading Standards to check inaccuracies and pumps are sealed after calibration (still with a wire and lead seal!).
Petrol stations use 'forecourt servicing and calibration companies' and a record should be kept at each premises. Can't remember now if calibration has to be done every year or two years (it's a while since I worked in the industry).
Unfortunately...
The accuracy is within 5% and can be set at minus 5% if they want.
So, your 60 litre registered fill could have been 57 litres!
Should imagine supermarket pumps would be set accurately (wouldn't they?),
but smaller companies with tight margins??
No, they wouldn't do that to their customers.... :whistle:
Threads: 9
Thanks Given: 2
Aha I didn't realise... interesting about the 5% margin. Maybe you just got a slightly larger fuel tank
Threads: 23
Thanks Received: 24 in 15 posts
Thanks Given: 11
Dont forget there will some be ullage space, otherwise if a plastic tank is full to the brim and it takes an impact it will tend to crack/split rather than deform due to the incompressability of liquid.
