  • 7 Vote(s) - 3.57 Average
[Engine] engine will not restart for approx 5 hours
I am trying to sort out a colleagues fault on his 03 1.9 hdi with a siemens 801A common rail, its a shaggy dog story so please bear with me.
The vehicle was bought with the fault and driven from birmingham to Cornwall with no issues.
The fault is that the engine will start from cold ok but once the engine has run, even for a matter of seconds it will not restart for approx 5 hours, when he collected the vehicle he left it running whilst refueling so no problem but once home he switched off and it would not restart.
I have carried out a pin to pin continuity test on the engine to ecu the wiring is all ok the connectors are in good condition and both the cam and crank sensors have been replaced with new ones. The injectors have been replaced due to out of limit leakback with good ones that have been checked for leakback - within spec. The HP pump has been tested using a blind pressure tool - 1350 bar so all is ok there. Using a dual trace scope cam, crank, rail, hp pump volume and pressure sensors and peizo injectors are showing ok. Rail pressure rises fast when cranking and when the fault is present it is only the injector pulse that is missing. Performance and economy is good with no smoke present at all. I then was guided down the ecu route by a contact that felt it was getting into a loop that prevented a restart, however I am beginning to suspect that its perhaps the immobiliser that is the root cause but I cannot find a wiring diagram showing how the ecu is connected to the immobiliser - which pins and when etc. Any advice will be gratefully recieved.
Hi, the engine Ecu comms with the Bsi which checks the key for the right code etc.
The best way to diagnose this would be to find someone with Lexia and get a read see if the Ecu is locking out. (immobilized)
Apart from that, it could be a heat related problem but if it's always approx 5 hours then it's unlikely.
Have you tried a Bsi reset?
http://www.bba-reman.com/content.aspx?co...ot_process
Confusedalut:
Thank you for the reply, yes I have reset the BSI and followed the battery shut down and wake up procedure on a number of occasions. Are you aware of the circuitry to the ecu? I feel sure that a supply or earth is being lost and preventing the ecu to go into it`s run mode, this seems to be possible as the ecu only isolates the injectors when engine shut down is initiated, with the rail pressure being reduced by the hp pump valves once the engine has stopped.
I know it`s a long shot but if I could just get a wiring diagram even if it proves me wrong then I would feel I was getting somewhere.
Thanks again for your assistance Rustscrat
(26-09-2012, 04:03 PM)ian Wrote:  Thank you for the reply, yes I have reset the BSI and followed the battery shut down and wake up procedure on a number of occasions. Are you aware of the circuitry to the ecu? I feel sure that a supply or earth is being lost and preventing the ecu to go into it`s run mode, this seems to be possible as the ecu only isolates the injectors when engine shut down is initiated, with the rail pressure being reduced by the hp pump valves once the engine has stopped.
If you can PM me your vin No. I'll dig out the correct ones.Confusedalut:
Good afternoon Rustscrat
The vin is VF7GJRHYK93080232
If you can assist me with a diagram and/or connector pinouts I would be most grateful
Regards
Ian
Are these any good to you?
Let us know how you get on. Confusedalut:
[Image: 2im12rn.png]
[Image: 30i7xc2.png]
Good morning Rustscrat
Yes, this is exactly what I was seeking, do you perhaps have the unit identifications too as some items are not so obvious to me from the diagram
Thanks again
Ian
(28-09-2012, 09:58 AM)ian Wrote:  Good morning Rustscrat
Thanks again
Ian
I don't have a list as such but if you can list the item No's I'll identify them for you. Confusedalut:
hi there did you ever get to the bottom of this problem?
KPH display
Yesterday 11:39 AM
Jealousy, loyalty, the French.... and Starter Mo...
Last Post: Wakou
Yesterday 06:57 AM
UK residents take note!
Last Post: Eamon Devlin
13-07-2025 12:47 PM
Hello guys.
13-07-2025 10:04 AM
Touchscreen update
11-07-2025 01:41 PM
10-07-2025 10:09 PM
Adding aircon oil after component replacement
Last Post: Ian_99
10-07-2025 08:10 PM
Spare key programming ?
10-07-2025 02:37 PM
Rear electric window regulators
Last Post: phydaux
09-07-2025 10:27 PM
Problem Passenger Electic Window
Last Post: pavb2
09-07-2025 06:49 PM
