  • 8 Vote(s) - 2.75 Average
Fuse box support in engine compartment - tow electrics
Dear members,
I am installed a genuine twin electrics towbar to my 2010 vehicle. Can anyone advise how to remove the engine management system in the right hand side of the engine compartment? I need to remove the 3 connectors and then remove the management system in order to fit a 40amp large fuse. The engine management system has a metal casing with only one connector fully visible on the left but I need to remove right to left to get them off but metal casing covering 50% of the top. I can see the fuse line behind the engine management system but can't work out how it slides up and out. The Citroen instructions show the diagram but their picture doesn't have a metal casing. Help appreciated as cant complete the electrics as no power to rear
Kind regards
Bdm2510
Resloved - simply ignore the instructions manual if you have a casing around the Engine managment system. Look at the fuse box on top of where the large fuses you are trying to find are located. Simply unbolt the earth cable, a gently unlipe the 3 plastic clips which hold the fuse box down. Pull gently up and then you will see the large fuses emerge. Simply put fuse in and gently clip back into place and bolt earthe cable again. Great when you know how.
[-] The following 1 user says Thank You to Bdm2510 for this post:
  • andy-womble
Solved
Can i get away with 205/70r15
Yesterday 11:38 PM
How I installed an oil catch can in the 1.6HDi
Last Post: saskak
Yesterday 09:59 PM
Eco-mode behaviour . . . .
Last Post: Lighty
Yesterday 09:46 PM
Juddering when pulling away
Last Post: dumdum
Yesterday 09:33 PM
Hello new member and warning light issues.
Last Post: Jamespworth
Yesterday 08:44 PM
Witter PG46C Towbar 2008 on
Last Post: Jakejjt
Yesterday 08:28 PM
Steel wheels wanted
Last Post: Jakejjt
Yesterday 08:10 PM
Driver door lock problem help!!
Last Post: SantubearSex
Yesterday 07:36 PM
Reimo Vertic cabin tailgate tent
Last Post: BerlingoAndy
Yesterday 07:14 PM
Pioneer double din
Last Post: dumdum
Yesterday 07:11 PM
