  • 5 Vote(s) - 2.4 Average
Oh No!
HI All,
After over a week of trouble free motoring when it was difficult to find fault with my 03 1.9 Multispace,my stomach sank while doing my first weekly fluid checkSad.Opening the coolant reservoir cap I was confronted by thick black oil in the coolant.There doesnt seem to be any water in the oil,and the exhaust is perfectly clear.Ill take it to the garage I bought it from tomorrow,hopefully its just a oil cooler problem.:eek: Very disappointing.
Sorry to hear that. Just be firm with the garage.
  • Les
What oil cooler? As Coco says, stand your ground with the garage. I hope it isn't anything too serious.
Malc
Stupid computer!
[-] The following 1 user says Thank You to crickleymal for this post:
  • Les
Isent the oil cooler between the oil filter and the block? I assume my engine has one as two water pipes go into the oil filter housing and they gargle the header tank when sqeezed.
Les.
Think you are right on this one Les.... Not a oil/Air cooler but an oil/Water cooler...
  • Les
Went to see my machanic this morning(well yesterday morning now)and when I told him about the oil in the expansion tank he dismissed it.He said 'Oh that will clear,oil was getting into the water thats why I changed the head and radiator'.He took a rag and wiped the oil off the surface of the coolant.Admittedly it looked a lot worse than it was, only a few mm,s thick.I dont know why he dident tell me to expect it instead of letting me make a fool of myself.Anyway I syphoned the header tank a couple of times myself and put in a litre of fresh coolant and all seems clear now(apart from a few rainbow streaks) even after a trip Moffat and a 75mph return journey via the A74M motorway.
Yesterday 12:02 PM
Berlingo 2026
Yesterday 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
