  • 7 Vote(s) - 2.71 Average
No feed to Glow Plugs
Hi all, i have an 04 Berlingo 1.9d which is struggling to start in the mornings, i have noticed that the glow plug light on dashboard is no longer coming on. it went for an MOT and i got the guy to check the glow plugs which were fine but he said there is no feed to them ?? Any ideas if this will be causing the starting issues and how to solve?
Cheers
Need to check the wiring and relay but where they are situated I don't know.
The older engine definately relied on glow plugs to start, similar to my old Pug 306.
Could always tell when a g.p. was down as started with a miss-fire until cleared and loads of white smoke. If more than one g.p. failed it would struggle or fail to start.
Welcome gottagetaname to the BOF...hope you get it sorted.
MPV (My own Personal Vehicle)....2.0 HDi Multispace MPV Mk2 .
I Like Cars,Women,Drink & Motorbikes but not necessarily in that order!
ok, its had a few wiring issues, the horn was working intermittantly when engine was on however it worked without the key in, i took it to an electrical place and they said it looked like a bad earth so for ease/cost they just re-routed the horn to an independant button on dash.
Hi, The relay is situated under the battery tray at the back. This is what ensures correct pre/post heat times etc... you can bypass this to check whether it is operational. The glowplugs are connected together by a thick wire which runs to the relay via the plastic manifold above the plugs. This connection can easily be unscrewed and run to the battery + with a jump lead etc. Give it 10 or so seconds to heat the plugs and try and start. If this doesn't work then plugs could still be at fault. Otherwise check all connectors/ wiring from relay to plugs and battery, something could have shaken loose... good luck check these obvious things first though..
adam
[-] The following 1 user says Thank You to adam3rdcanvey for this post:
  • Andre
Thanks for the advice i will give it a try!!
[-] The following 1 user says Thank You to gottagetaname for this post:
  • adam3rdcanvey
cheers bud,
send me a message if you can't find the solution, and i'll try and post some how to photos for ya.
have had many issues with my van but there is always a simple solution!
adam
Modutop Door Hinges - Cable tie repair
Last Post: LukeLog
Yesterday 11:05 PM
Plug phone into stereo?
Last Post: LukeLog
Yesterday 10:03 PM
Last Post: Grizz
Yesterday 07:27 PM
» Replies: 626
How did the Berlingo get it's name ?
Last Post: hawaiianblue
Yesterday 05:30 PM
Full 1.9D Van Spares
Last Post: TONX
Yesterday 04:45 PM
new vehicle
Yesterday 02:51 PM
Loose connectors under dash
Last Post: Hooligan
Yesterday 12:31 PM
Coil pack for 1.4 petrol
Last Post: dumdum
Yesterday 09:19 AM
How Often Does AC Need Re-Gassing?
Last Post: Luis Rosa
Yesterday 06:28 AM
THE ITALIAN BOX ?
Last Post: THE BADGE
16-01-2019 09:29 PM
