key fob change-over: can't get the blade out!
Threads: 4
Thanks Received: 4 in 3 posts
04-10-2012, 10:26 PM
(This post was last modified: 04-10-2012, 10:27 PM by chevrons2.)
Hi.
I've got a pre-facelift 2002 multispace.
My key-fob buttons have disintegrated so I've bought a new case (ebay) and transferred all the internal bits over, except for the key-blade itself: I can't see how to get it out of the casing! The new casing has a small hole at 90 degrees to the blade hole, so I assume that the blade must also have a hole in it and this is for a pin to hold the key blade in place. This doesn't help much though because the old fob is different there: no hole or pin; just what looks like solid plastic, which appears to be part of the fob casing. So does anyone know how I get the one blade out?: Do I have to destroy the old casing around it? Thanks
Threads: 47
Thanks Received: 15 in 12 posts
Thanks Given: 4
You would have been better off going to your local Citroen dealer and getting a new key programmed for your vehicle, its easier and less hassle.
Threads: 50
Thanks Given: 743
05-10-2012, 01:07 PM
(This post was last modified: 05-10-2012, 01:13 PM by Ol'Jeffers.)
(05-10-2012, 11:45 AM)pitpan Wrote: You would have been better off going to your local Citroen dealer and getting a new key programmed for your vehicle, its easier and less hassle.
Maybe in OZ.....
In the UK :
Main Dealer.....around AU$ 125
Citroen repairer around AU$ 95....OUCH!!
Threads: 4
Thanks!
Has anyone got any constructive answers please?!
Threads: 3
Thanks Received: 22 in 13 posts
Thanks Given: 15
Hi there, I recently found my key was getting a little worn and I had to fiddle about before it would turn. I purchased a blank off ebay, item number: 130694748554 then took it to our local key cutters and had it cut from my wife's good key. Then just had to transplant the guts from old Key not forgetting the transponder chip. Works great and total cost just £8.30. Hope this helps. Dave.
Smile it's already happened!
The following 1 user says Thank You to trader97 for this post:1 user says Thank You to trader97 for this post
• whitebus
Threads: 4
(06-10-2012, 06:40 PM)trader97 Wrote: Hi there, I recently found my key was getting a little worn and I had to fiddle about before it would turn. I purchased a blank off ebay, item number: 130694748554 then took it to our local key cutters and had it cut from my wife's good key. Then just had to transplant the guts from old Key not forgetting the transponder chip. Works great and total cost just £8.30. Hope this helps. Dave.
Thanks for the reply Dave. I have already bought a key-fob case that looks exactly the same as the one you refer to but mine had no key-blade attached. I have swapped all the internal bits over without any problem but I can not see how to get the key-blade out. It's obvious how it goes in the new one, (as it's the same as in the lower picture in that ebay listing, but with the screw missing), but the old one is different: it has no hole for a screw. So how is it held in? More importantly, how can I remove it without damaging it? Also, as it's different, will it fit in my new casing?
Threads: 3
Thanks Given: 15
Hi, to be honest one of the reasons I bought the fob with the blade already fitted was because I too could see no way of removing the old blade. I think even if you did get it out I doubt it would fit the new fob properly. It looks like you would damage the old fob getting it out. It just seemed simpler to buy the fob with the blade fitted and get it cut as it wasn't expensive. Sorry I can't offer better advice but that was my experience. Dave
Threads: 4
(08-10-2012, 10:04 AM)trader97 Wrote: Hi, to be honest one of the reasons I bought the fob with the blade already fitted was because I too could see no way of removing the old blade. I think even if you did get it out I doubt it would fit the new fob properly. It looks like you would damage the old fob getting it out. It just seemed simpler to buy the fob with the blade fitted and get it cut as it wasn't expensive. Sorry I can't offer better advice but that was my experience. Dave
Ok. Thanks Dave
Threads: 19
Thanks Received: 30 in 19 posts
Thanks Given: 38
08-10-2012, 09:18 PM
(This post was last modified: 08-10-2012, 09:27 PM by Mindyerlingo.)
Is it the square "Fick knife" type you have?
Sorry about grammar, I meant Flick knife of course
Threads: 4
(08-10-2012, 09:18 PM)Mindyerlingo Wrote: Is it the square "Fick knife" type you have?
Hi. No, it's a fixed 2-button fob, like item number 110954346365 on ebay. Externally it looks exactly the same (apart from having chevrons on the buttons). Internally (see the second picture on the ebay listing) it's all the same except that it hasn't got the hole for the screw that holds the key-blade in, and that rectangular part of the casing (around where the blade fits in) is slightly bigger.
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
20-10-2026 06:45 PM
» Replies: 45
18-10-2026 06:46 AM
» Replies: 82
17-10-2026 05:41 PM
