  • 12 Vote(s) - 3 Average
Engine Drain Plug, grrrr
Bloody Citroen. I get under the car to take out the drain plug. It appears to be a hex socket type thing. So I get my hex sockets and find that 8mm is too small and 10mm is too big. What numpty puts a 9mm screw in. They don't ordinarily exist. Or am I missing something?
Malc
Stupid computer!
Try Amazon or your local Hellfrauds!
http://www.amazon.co.uk/dp/B000LFVNT6/?t...B000LFVNT6
Of course the Hellfrauds socket will be very expensive (probably)!
I've just been out and bought one from Bell Tools. It's just annoying that they can't use a fairly standard size. Now I've got to wait for everything to cool down before I can get to work and seeing as I've got to go out again it'll delay things a whole day.
Malc
Stupid computer!
C'est la vie :whistle::whistle::whistle:
You Can use a 24mm socket with an extendable wheel wrench for leverage if possible.
Well I do anyway.
(05-10-2012, 09:54 AM)crickleymal Wrote:  It's just annoying that they can't use a fairly standard size.
It's deliberate. Citroen know that draining and changing oil is a simple job so they deliberately use a non-standard size so you can't do it unless you buy the correct tool.
That then gives them the opportunity to charge £35 for the oil and
£75 for the labour!!:brickwall:
[-] The following 2 users say Thank You to Ol'Jeffers for this post:
  • ron, Rustscrat
(05-10-2012, 09:05 AM)crickleymal Wrote:  Bloody Citroen. I get under the car to take out the drain plug. It appears to be a hex socket type thing. So I get my hex sockets and find that 8mm is too small and 10mm is too big. What numpty puts a 9mm screw in. They don't ordinarily exist. Or am I missing something?
Welcome to the world of B'stard sizes, 7mm, 12,15,18,21...........and so on. Then there's the torx ones!! :brickwall:
All vehicles seem to be the same now, in other words "lets make it as awkward as possible". :censored:
  • ron
Torx55 on the front brake calipers, it's a massive bolt, slightest bit of rust and you can't get it off. Not enough leverage with the torx bit.
I spent hours last week getting mine off my 2002 van, ended up grinding the bolts off!
Replaced with standard bolts.....
(05-10-2012, 04:51 PM)steve valentine Wrote:  Replaced with standard bolts.....
That's what I'm doing over time. As I need to remove something, any Torx fitting is replaced with a proper bolt. Sods Law I'll never need to remove it again, but for the sake of a few pence every time it's peace of mind for the future
(05-10-2012, 04:32 PM)Rustscrat Wrote:  Welcome to the world of B'stard sizes, 7mm, 12,15,18,21...........and so on. Then there's the torx ones!! :brickwall:
Vauxhalls have been doing it for years, what's wrong with the "Stock" sizes ie. 11,13,17,19 etc etc
Last Post: BDRichardson
Today 04:07 PM
Yesterday 09:56 PM
04-09-2026 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
