Threads: 19
Thanks Received: 30 in 19 posts
Thanks Given: 38
Anyone fitting reversing sensors or got them like me (without disable switch I hasten to add) may like this. On your computer search engine
type in 9452.95 or 9690.07. Good pictorials / photos of how to measure and fit sensors, electrical harness tie in points. Bit like the old Haynes manual photo's, rear lining panels removed, bumper off etc. Most Berlingo's are listed and shown as well as a few other Citroens and Pugs. I found it really helpful when tracing my system,
hope you do too.
Threads: 52
Thanks Given: 87
5
Wow, way cool. Many thanks
Threads: 29
Thanks Given: 67
20
If it's to the pdf try
this link
Threads: 8
Thanks Received: 32 in 16 posts
Thanks Given: 16
4
This seems to be referring to a PDF document online that has in fact been split into two parts/links. The part of the document that refers to instructions for Berlingos (mark 2 and mark 3) is in the second part - here is the link:
http://www.citroen-auch.com/fiches/945295_T2.pdf
2012(62) XTR 1.6 92bhp Airdream Modutop
I have a y reg 2000 Berlingo. The key fobs need to be reprogrammed. A how to guide would be great. My main issue is where is the location of the transponder at the front of the car to hold key near to to programming the key. Any help would be great.
Threads: 6
Thanks Received: 4 in 2 posts
Thanks Given: 1
Hi
Great link
Does anybody know if my 2011 berlingo will have the loom for reverse sensors built in before I start pulling it apart on a discovery mission.
Threads: 8
Thanks Given: 16
4
(25-09-2016, 06:16 PM)Carl Davis Hulin Wrote: Hi
Great link
Carl what year and spec is your car? the video i put on youtube showing how to pop open the boot panel may be useful. quick way of checking if you have that loom in place.
