07-10-2012, 09:16 AM
Hi all, so ive been having a problem with an intermittent idling issue. with so many possible sensors to blame i decided to get a cloned Lexia scanner off ebay.
after finally getting the software to install i cant get it to connect to my berlingo? it just says error connecting etc...
It just seems like theres no power to the obd socket? so i had a look at the fuses and did a BSI reset as well this morning.
problem is my fuse box is a mess. i have fuses in sockets that dont do anything e.g. heated seats that i dont have and incorrect Amp on some things like the 12v lighter and the radio and others.
but everything works just fine?? do i go by the letter of the haynes manual and take out the ones i dont need and replace all others with the correct amps??
what else could be coursing my connection issues? I have a Y reg 2001 Mk1 1.9d
Thanks Ricky
Thanks Ricky
