Thanks Given: 4
the offside rear door on my 2007 Berlingo will not unlock. Previously it wouldn't lock with the key fob so we had to put down the child proof lock but now we can`t open the door at all. very inconvenient? anyone any ideas? Thanks, Mik
Threads: 51
Thanks Given: 23
Nothing to do with the petrol cap is it?
Malc
Stupid computer!
Threads: 32
Thanks Given: 24
There is an interlock. When you remove the fuel cap, it operates a switch which in turn prevents the O/S rear door being opened.
This is to stop someone opening the door into a fuel nozzle.
It may be that the switch is faulty.
The following 1 user says Thank You to Coco for this post:1 user says Thank You to Coco for this post
• mik
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
Beat me to it, again, Coco.
Fuel cap interlock. Possibly.
The following 1 user says Thank You to j90xxx for this post:1 user says Thank You to j90xxx for this post
• mik
Thanks Given: 4
i assume this isn`t something that you could mend yourself? Thanks, Michael
Threads: 23
Thanks Given: 46
5
(10-10-2012, 03:23 PM)mik Wrote: i assume this isn`t something that you could mend yourself? Thanks, Michael
The best way to test it is to open and remove the locking fuel filler cap then replace it. This worked for someone a week or two ago.
The following 1 user says Thank You to Trevor for this post:1 user says Thank You to Trevor for this post
• mik
Thanks Given: 4
Thanks. Have tried this after a previous reply but not worked so far. Will try it again.
Thanks Given: 188
23
This problem was a usual on Renault kangoos so when you took the fuel cap off the door would lock but it used to play up stopping that door locking or being locked all the while. On the renaults the switch in question was mounted inside the car up next to the filler neck and had a micro switch or reed switch. Some people just bypassed it or repaired it. I bet citroen use the same system, sorry I can`t be of more help.
Are we there yet?????
• mik
