Lexia help please - Airbag lights
Threads: 32
Thanks Given: 24
15-10-2012, 02:39 PM
(This post was last modified: 20-10-2012, 06:30 PM by Coco.)
Well alright, it's Planet really but now I've got your attention...
I splashed out and bought a clone of Planet (Lexia). All connected and working O.K.
1) I'm trying to clear the airbag lights but can't, I get the following:
Airbag ECU = "Permanent fault VAN network" - "Passenger airbag deactivation"
I've removed and remade the connections under the seats and removed cleaned and replaced the deactivation switch at the side of the dash, all to no avail. I've taken out and cleaned the airbag ECU and checked it's earths which were good.
2) It also shows on the BSI "Permanent fault communicating on the DATA wire with the engine wiring housing"
I've taken out and replaced the BSI, all connections were good and all fuses intact.
3) Whether this is related or not, I also have a fault code 0483. I think that this relates to the cooling fan, which I have yet to explore
Any ideas please??? :brickwall:
The following 1 user says Thank You to Coco for this post:1 user says Thank You to Coco for this post
• Multispacer
Threads: 18
Thanks Received: 468 in 294 posts
Thanks Given: 211
15-10-2012, 09:29 PM
(This post was last modified: 15-10-2012, 09:32 PM by Rustscrat.)
The "engine wiring housing" will be the engine bay fuse box(Bsf).
Both these units (a,bag ecu & Bsf) use the same Comms and are both fed off the same Comms fuse - No. 14 in the Bsi.
Whilst poking around the Bsi, check for water damage or coffee etc.
I've had three of these units now all with comm faults due to liquid  illyme:
Does the reader say "Data A" or "Data B" maybe?
Let us know how you get on.  alut:
2006 2.0hdi 600 with bench seat.
Threads: 32
Thanks Given: 24
Thanks, I was hoping you'd turn up !
I've not had the plastic cover off the BSI yet, but there was no sign of water contamination anywhere - I'll have to look further.
No mention of Data A or B, just "DATA wire". Hope to have half an hour to have another go at this tomorrow morning, I'll keep you posted.
Threads: 32
Thanks Given: 24
Well the BSI shows no signs of any fluid ever being near it, completely unmarked.
All fuses good, also all engine bay fuses good. No 14 on the BSI changed just for good measure.
On restarting no change, still have two airbag lights. I can't hook up Planet because the diagnostic socket has disappeared !!! It's come adrift from the plastic trim and I don't have time to dismantle half the dash to find it before going to work. Job for tomorrow then !
Threads: 18
Thanks Given: 211
17-10-2012, 01:59 PM
(This post was last modified: 21-10-2012, 09:07 AM by Rustscrat.)
(17-10-2012, 09:15 AM)Coco Wrote: Well the BSI shows no signs of any fluid ever being near it, completely unmarked.
Same happend with mine, I managed to get my hand round the back and push it back in! :whistle:
Threads: 18
Thanks Given: 211
Coco, just been trying to simulate your faults on my test rig and found that if the Bsf has data problems it brings up the air bag fault. Not saying it's the same for yours as this is a different engine (DW8B) but air bag won't clear until the Comms are sorted.
Did you notice any faults with the "controls under the steering wheel" ?
 cratch:
Threads: 32
Thanks Given: 24
No, all column mounted controls work as they should. Going out to have another go in a minute (after changing the power steering fluid) so I'll report back later.
Threads: 32
Thanks Given: 24
Tried again and still no joy.
Tested the Comm 2000 and no faults found. The others remain as they were before.
Threads: 18
Thanks Given: 211
Check the 10 pin connector "EP1" in the engine fuse box, check for corrosion etc.  alut:
Threads: 18
Thanks Given: 211
18-10-2012, 02:24 PM
(This post was last modified: 18-10-2012, 02:34 PM by Rustscrat.)
Just been having another play and found out that your air bag fault translates to this - "There is a fault on the Van network. The passengers air bag has been deactivated."
So I think the fault lies with the Comms to the engine fuse box (Bsf) on your "data" wire (9012 red, pin 1 EP1(10v NR) Bsf, pin 6 EP(40v NR) Bsi).
 alut:
dw10 air bags.pdf (Size: 162.85 KB / Downloads: 535)
Users browsing this thread: 3 Guest(s)
A Testing Question....
Today 03:53 PM
Wheel nuts
Today 10:16 AM
Yesterday 04:31 PM
Yesterday 11:13 AM
Last Post: JPCoetzee
15-03-2026 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
