Threads: 6
Thanks Received: 3 in 2 posts
Thanks Given: 17
does anyone have an air con unit available for a 53 plate 2.0 hdi? the squealing is doing my head in lmao
cheers
Doc
Threads: 43
Thanks Received: 416 in 373 posts
Thanks Given: 137
33
"does anyone have an air con unit available"
What do you mean?
The compressor pump or condenser. ?.
If the drive belt is slack/loose then squeals expected
If its the compresser pump bearings then you would get a squealing noise but it could also be alternator, tensioner or steering pump bearings.
If its not working then its not working either to compressor pump failure, gas leak or pressure sensor. Usually a noise like a gurgling noise from behind the dash where the evapoator sits indicates low gas pressure. Condensor damage due to a stone etc. causes a leak.
Threads: 6
Thanks Given: 17
yeah sorry the compressor pump is what im after, my mate had it up on the ramp at his work last night. i originally thought it was the middle idler on the fan belt but after closer inspection it turned out to be the air con.
the funny thing is..... i didnt even know the van had air con till last night lmaooo there is no button or any indication at all of it being present while your sat in the cab!
thanks for the info mate, much appreciated
Doc
