  • 10 Vote(s) - 2.2 Average
Unable to bleed brakes after changing rear axle.
Hi,new to forum. Have just got rear axle repaired 2006 1.6HDI van, ABS,but now can't get brakes to bleed. engine off pedal is hard, but engine running pedal goes very soft and stop and brake warning lamps flashing. Any "how to's" out there?
Thanks in advance
You can bleed manually but it's hard on the leg muscles & slow.With the aid of an assistant,open nipple,pump pedal,close nipple,lift pedal & repeat.If you have a pressure bleeder so much the better.Good luck.
  • airman
Probally air in the rear brake pipes ,
With ABS a pressure bleeding kit should be used.
Switch OFF ignition as you can knacker the brake hydraulic modulator if its activated while being bled. (pressing the pedal with ignition on.) :censored::censored::censored:
  • airman
Sorted at last. Took the advice and bought a Gunson easi-bleed kit, worked first time! Thanks for the quick response and advice.
Last Post: rom4ik
Yesterday 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
