Threads: 63
Thanks Given: 410
Sorry to be the prophet of doom !!!!
Technically I suppose it it feasable but first of all you need to consider the legalities of fitting extra seats.
You may well find that un-approved alteration/modification could void your insurance and the vehicle may have to be type approved by the Vehicle Inspectorate and would also have to pass the annual M.O.T. test.
The vehicle would also have to have provision for extra seat belts and approved anchoring points for them.
The days of fitting or even placing an extra bench seat or similar in the back of a motor are, I am afraid, now frowned upon and outlawed
Threads: 52
Thanks Received: 82 in 67 posts
Thanks Given: 9
Hi Kate
The mk 1 did have the option of a couple of fold down seats in the boot, so in theory they could be retro-fitted.
[Image: 7seat.jpg]
However, converting a five-seater would cause the issues as Andy mentioned, plus for vehicles manufactured after 2006 side facing seats were banned altogether for (lack of) safety reasons.
Thats what my partner has said he wanted our car is a 2003 model so this still may be possible right?
Threads: 52
Thanks Given: 9
I don't think that the mk2 (which is what a 2003 car will be) ever had type approval for the extra seats. If that is the case, then I think that you would have to have to go through an SVA (Single Vehicle Approval) test before being able to legally use the seats to make sure that they are compliant. Even with this, insurance will be an issue and the DVLA would need to be notified.
If the original Citroen seats were simply bolted in, then you might be lucky and find that the mk2 still has the same fixing points, but it does seem like a lot of work for something that at the end of the day is not going to be particularly comfortable nor safe. It is also worth bearing in mind that it is illegal for children under 12 to travel on any side-facing seat.
Threads: 52
Thanks Given: 9
Basically, the best advice is don't do it. I looked into the subject recently in respect of Landrovers and side-facing seats, and on the basis of what I found I certainly wouldn't want to sit there, let alone put friends or family in that position, even though someone will say that they spent their childhood bouncing around in back of a Landrover, when Woodbines were good for you and lead water pipes were a sensible idea, yet none of it did them any harm
One study was carried out in Australia following a fatal accident involving an army Landrover. In that case, four soldiers were killed in an accident at just 45 km/h (30mph!) while sitting in side-facing seats. Subsequent investigations concluded that with both lap, and 3 point belts, there is the
likelihood of life-threatening injuries in a 48 km/hr collision. In fact, evidence suggests that you are less at risk without a seatbelt on a side-facing seat.
With regards to UK law, from the Department for Transport "a child who is required to use a child seat/booster (ie, all those under 135 cm tall who are also under 12 years old) cannot travel in a sideways-facing seat. A child who needs to use a child seat or booster must use a forward or rear-facing seat."
