  • 4 Vote(s) - 1.5 Average
starter problems
hi everyone,
was getting problems with starting my 1.6 hdi the starter was intermitantly turning over slowly thought it was the alternator or battery but checked the voltages they seem fine charging at around 14.5v at the battery posts so i guess it must be a dodgy starter anyone else had any problems with starters on these
I've had 2 new starters on my mk2 1.6 petrol.
(20-10-2012, 01:15 PM)st220 Wrote:  hi everyone,
I'm sure you will have checked already, but if the battery connections are loose or corroded, it can cause the starter to turn over slow, but still read OK on a multimeter.
Married to BandanaLady.co.uk
Check ALL earth connections,bat to earth,engine to earth.Check voltage at starter live term,should be batt voltage.Check starter terminal security incl solenoid lead. Good luck.
thanks for getting back to me i will check all the connections in the morning you could be right to be honest cause the intermitent fault seems to go away when it gets wet outside gotta also check the air flow meter so the tester is gonna get a lot of use lol
Apple Carplay
02-04-2026 01:26 PM
Last Post: Transmit
02-04-2026 11:21 AM
