  • 3 Vote(s) - 3 Average
Heater Blower, running constantly
Hi, I have changed the transistors on the blower as it was on full.I followed the instructions here -http://www.johnandchris.screaming.net/be...blower.htm it is now working but it is running very slowly even in the off position.only noticed it because I was testing before installing. Is this normal?
I think theres a clue in the word Off.
Have you tried a search on the forum ? I think this subject has been discussed before.
Yeah that is correct. It is supposed to spin slow even when off as the resistor pack simply slows down the fan, it never actually stops it running completely.
Mine is exactly the same and it's normal.
[-] The following 2 users say Thank You to tucker for this post:
  • john66, ron
Thanks tucker, I can now put it all back together.my van appears to do the same when the engine is running,never noticed it before.
Yes, stick it back in, it's working correctly.
The fan is designed to run at full speed. The resistors then adjust that speed down when you use the settings. Hence when the resistors break the fan just runs full pelt all the time. They never stop the thing spinning completely and if you open your vents with the fan off, you will still always get a very slight trickle of air through them, but it's hardly noticable.
[-] The following 3 users say Thank You to tucker for this post:
  • CandR, ron, Rustscrat
Driver door lock problem help!!
Last Post: ryanadam
Today 05:24 PM
Berlingo 2.0Hdi 2003 multi wont rev past 2000RPM
Last Post: peterbol
Today 02:16 PM
No abs
Last Post: mrnorth
Today 01:58 PM
Steel wheels wanted
Last Post: Art b
Today 12:45 PM
Juddering when pulling away
Last Post: magoo
Today 12:17 PM
starter motor issues
Last Post: malgpz900
Today 08:22 AM
Can i get away with 205/70r15
Today 08:13 AM
Last Post: Grizz
Today 07:27 AM
» Replies: 702
Titsup
Last Post: Martinez
Yesterday 07:05 PM
Hello new member and warning light issues.
Last Post: Jamespworth
Yesterday 06:42 PM
