Threads: 6
Thanks Received: 3 in 3 posts
Thanks Given: 2
25-10-2012, 01:34 PM
(This post was last modified: 25-10-2012, 01:35 PM by GJT.)
Since yesterday the ABS warning light comes on as soon as I start the engine on my '09 XTR 1.6Hdi. It doesn't come on during the initial checks after switching on the ignition. Are there any electrical connections I should be checking first before I get it investigated properly? I see from the handbook states that normal braking is not affected so it's not desperately urgent as I'm not likely to encounter muddy or icy roads at the moment. Fluid reservoir is full.
Threads: 43
Thanks Received: 42 in 37 posts
Thanks Given: 3
had that on my 04 and it was the plug under the seat.mine were broke but ive seen quite a lot on here that had just undone the plug and then pushed the plug back together and it was sorted.
Threads: 81
Thanks Received: 395 in 338 posts
Thanks Given: 165
20
(25-10-2012, 03:44 PM)OlJeffers Wrote: (25-10-2012, 03:35 PM)landcrab Wrote: had that on my 04 and it was the plug under the seat.mine were broke but ive seen quite a lot on here that had just undone the plug and then pushed the plug back together and it was sorted.
What!!?? For the ABS??
cratch: I thought that would only affect the Airbag Warning Light.
Air Bag System!:lol:
