1.9 DW8 suddenly sounding like a vintage Tractor!
Threads: 4
Thanks Received: 14 in 4 posts
Thanks Given: 8
I've a 54 plate Van which suddenly went from running totally normally to sounding like a tractor - severely excessive diesel knock - as well as being difficult to start. Fortunately, having invested in a code reader, it gave a DTC of P1106 with the text of 'Advance Regulation Electrovalve short circuit or open circuit.'
The Haynes manual refers to the above as an Advance solenoid with the caveat of leave it to a dealer......The hardest part was locating in on the fuel pump. It's accessible from the front, low down and attaches a fuel pipe. There is a flat cable running from it to a connector block which is difficult to see unless the air intake trunking is removed, not great even then!
The solenoid easily unscrews from the main pump, I used an adjustable spanner. A continuity test showed no circuit, agreeing with the code reader.
Now for the worrying bit. Phoned a Citroen dealer who wanted in the region of £340 for it. After recovering from the shock, I cleaned up the old one and revealed a Delphi part number of 152B. Googling this not only confirmed I had the right part but several hits for suppliers. The prices ranging from £64 Inc VAT to £135 + VAT. Guess which one I bought? From UK diesel parts.
Arrived today and quickly installed. Would the van start, like he'll it would! No further faults logged, done a BSI reset to no avail. Thought, basics, no fuel getting through, and after about 10 pushes of the primer get showered in diesel. Fuel pipe reconnected, a couple more priming shoves and it starts sounding normal again.
Hopefully my ramblings may assist anyone with similar problems as the manual was useless. Infact the only decent pointer I got was on the French Car Forum.
Regards Tubby
Threads: 50
Thanks Given: 743
Well done Tubby! This is the sort of money saving info we like here.
Here's a link to the supplier:
http://ukdieselparts.com/manufacturers/c...troen.html
Threads: 4
Thanks Given: 8
See the attached image that I should have posted earlier
Threads: 32
Thanks Given: 24
Thanks Tubby - that's what these forums are for
Threads: 67
Thanks Given: 238
50
Thanks for the info Tubby though I hope I'll never need it ! Fingers crossed.
I also hit the thank you button, don't often do that.
Serieal Berlingo owner
Threads: 13
Thanks Received: 91 in 80 posts
Thanks Given: 11
Fair play Tubby , nice one :thumbsup:
I can appreciate different firms have different overheads etc and everyone has to make a living but surely charging in excess of 5 times the price of a competitor for the same product is taking advantage of Joe public , there are plenty of people out there who only ever use main dealer facilities and wouldn't consider doing what Tubby did in this instance to get a better deal .
I suppose as not everyone has the ability to do the work themselves or the time or inclination then main dealers can charge what they like for convienience sake . Support your local independant , if you can , if you know of one  illyme: and then maybe if maindealers lost some trade they may appreciate us the paying customer and bring their prices down . I'll come down from me high horse now , rant over for now !
Thanks for info Tubby  tudy:
Threads: 4
Thanks Given: 8
Cheers for your kind words, it's a pleasure.
A interesting footnote concerns fault code readers. Initially I scanned with an EOBD ( ie non French specific) with no codes revealed. My understanding was this should have shown a DTC as diesels were included in the EOBD protocol from 2004 & petrol from 2001.
I know, need to get out more!!!!!!
The following 1 user says Thank You to Tubby for this post:1 user says Thank You to Tubby for this post
• RolyG
Thanks Received: 23 in 20 posts
Thanks Given: 18
old as heck thread, but my 1.9d done this momentarily on a long journey a few weeks back, again did it for about 10 seconds this morning, and then this afternoon it was permanent. unscrewed the solenoid, it didn't look too bad inside and just some surface rust on the outside, checked continuity and it was OK so put it back together again and tried the van with no air intake attached and it was mad smokey, thought id f**ed it and resolved to bringing it to the garage tomorrow, put the intake back on, fired it up and its fine now, just went a quick run and usual power (ie hardly any) and no noise, happy days!
Thanks Given: 18
(15-08-2021, 05:14 PM)miccheck1516 Wrote: old as heck thread, but my 1.9d done this momentarily on a long journey a few weeks back, again did it for about 10 seconds this morning, and then this afternoon it was permanent. unscrewed the solenoid, it didn't look too bad inside and just some surface rust on the outside, checked continuity and it was OK so put it back together again and tried the van with no air intake attached and it was mad smokey, thought id f**ed it and resolved to bringing it to the garage tomorrow, put the intake back on, fired it up and its fine now, just went a quick run and usual power (ie hardly any) and no noise, happy days!
spoke too soon, knocking is back and its smokey
Yesterday 07:31 AM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
OIL Drip
Last Post: Martinze
10-03-2026 06:08 PM
10-03-2026 02:49 PM
New owner in Bristol UK
Last Post: JPCoetzee
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
Potential Purchase!
09-03-2026 03:03 PM
Diagbox 7.57 download
08-03-2026 09:13 PM
