  • 6 Vote(s) - 2.17 Average
Jerky Steering
Hi guys
I have just started having problems with the steering on my beloved Berlingo......I did about 300 miles on the motorway came to turn off at the junction and had no power steering....managed to get around the roundabout ( just ) and then next thing it was ok.
Now it seems to be intermittent and jerky and also makes a little knocking sound....just went through MOT with now advisories so can't be cv joints or broken springs as mentioned on here before but I've no idea....can anyone help me ?
Cheers
Andy
Fluid level O.K.?
Aux belt tight?
As per Coco but is the fluid clean?If it's brown rather than red,suck out all you can & top up with fresh fluid.Repeat this weekly or 100 miles about 4 times.Check the first oil removed & it will probably look mettalicky.This should clear by the 4th change.If the steering improves,add a good additive for PAS & repeat every 2 years or 20,000 m.It's always cheaper to change oils/fluids regularly than replace components.(it's also safer)
cheers guys i'll have a look
(25-10-2012, 08:46 PM)ron Wrote:  As per Coco but is the fluid clean?If it's brown rather than red,suck out all you can & top up with fresh fluid.Repeat this weekly or 100 miles about 4 times.
I've just done that, not looking forward to next week as I've sucked out the fluid for this week,it don't half give you the shits mate...... (Spit don't swallow)...:whistle::whistle::whistle:
Only joking...
Actually, perhaps in hindsight, perhaps it should be stated that the fluid needs to be sucked or drawn off with a syringe or similar and not by contact with the mouth as it may be a wee bit poisonous...
  • RolyG
Only joking...
Or, get the wife to do it! :lol: :whistle:
[-] The following 3 users say Thank You to Rustscrat for this post:
  • brodfather11, RolyG, ron
The plastic cover that protects the aux. drive belt was missing off mine. When I hit a pothole when turning water splashed up onto the belt and I lost power steering, reversing out of my fence and revving it up turned the air blue.
:twisted::twisted:
After fitting new cover its never done it again
Turns out the garage couldn't find anything apart from rust on the U/J on the bottom of the steering column.....cleaned it all off, a little WD40 and spray grease and its sorted !!!
[-] The following 2 users say Thank You to peacey for this post:
  • adam3rdcanvey, ron
good to hear..... something simple for a change!!
Have you got damp mats or signs of water inside,this damp atmosphere can cause your problem.
I would still change the P.A.S. fluid.
Brake problems again!
Yesterday 08:47 PM
CITROEN VIRTUAL SERVICE MANUAL ALL MODELS
18-06-2025 05:34 PM
» Replies: 33
P0691 P0693 cooling fan circuit problem
18-06-2025 07:32 AM
Does My Van Have A Tracker ?
Last Post: Mark604
17-06-2025 03:01 PM
Last Post: Cumbrian
15-06-2025 09:02 PM
14-06-2025 10:57 AM
» Replies: 36
Last Post: Vlad
12-06-2025 02:36 PM
11-06-2025 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
11-06-2025 10:33 AM
Nearside Headlamp bulb change
10-06-2025 01:59 PM
