Threads: 2
Thanks Received: 1 in 1 posts
Thanks Given: 6
Hi new to all this so please be gentle with me!!!!
2003 1.9 non turbo
van runs lovley but between 45 and 55 mph i get a wooble through the whole van, not through the steering and only whilst accelerating. checked all the ball joints and all seem ok. changed all wheels and had them balanced... hope some one can throw some light on this for me....
The following 1 user says Thank You to stueight for this post:1 user says Thank You to stueight for this post
• taxi
Threads: 20
Thanks Given: 2,126
18
Have you checked the engine mountings?
Strawberry flavoured windows
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• stueight
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
Or the suspension mountings?
The following 1 user says Thank You to j90xxx for this post:1 user says Thank You to j90xxx for this post
• stueight
Threads: 2
Thanks Given: 6
Ron. Have checked all engine mountings.. Nothing!!
Martin Again checked all suspension top and bottom. Nothing
Getting very frustrated now. DOH!!!!!
Threads: 96
Thanks Received: 448 in 375 posts
Thanks Given: 709
Wheel bearings affect it in this manner ?
Former 2011 Mk3 XTR owner
alut:
The following 1 user says Thank You to taxi for this post:1 user says Thank You to taxi for this post
• stueight
Threads: 19
Thanks Received: 55 in 38 posts
Thanks Given: 19
I have this problem too and today have checked the left hand engine mount which, on my M59, is under the battery. It's actually a mount for the transmission. The battery is easy to remove but the tray it sits on less so. The mounting looked fine from the top but, having got so far I decided to remove it completely to check its underside. It's quite easy to remove after jacking up the gearbox. Centre nut first then the two others. The rubber underneath was soggy and oil soaked and, more importantly, the hole, which should be circular, was elliptical. I have today ordered a new one (£15) and we will see if it cures it. See my current post for the result. I bet this is your problem - the gearstick wobbles from side to side in second and third gears when accelerating.
The following 1 user says Thank You to mikeB for this post:1 user says Thank You to mikeB for this post
• stueight
Threads: 2
Thanks Given: 6
12-11-2012, 10:23 PM
(This post was last modified: 12-11-2012, 10:24 PM by stueight.)
Ok gents ive taken mikebB's advice and changed the engine mounts,( thanks mike) the top ones any way...... Can i change the bottom one engine transmission one with out having to remove the drive shaft first to get the mount backet off or a=can i just remove the rubber mount a nd put a new one in... I know that make it sound easy, but im sure it aint.... cheers.... sorry replacing the top ones have improved the wobb;e but still there to a lesser degree..
