  • 3 Vote(s) - 1.67 Average
Revesing Camera wiring help
I bought a reversing camera kit off eBay, with the intention of wiring it to the reversing light for switching but as there is a label advising not to connect anything exceeding 10mA and the camera is rated at 70mA I'm not sure how to wire this up now
I have thought of using one of the 12v outlets for power and adding some form of switch so that it isn't running constantly.
It does work off the reversing light but I am worried I could cause damage by leaving it connected there.
I'd appreciated any comments on how to wire this in.
Vinny
Sounds like you need a relay to switch the 70a.
Hi, where abouts is the warning Confusedcratch:
Seems strange as each reverse lamp (21W each) will draw 1.75 Amp.
And this circuit is protected by a 15Amp fuse.
Also you can tap off these for trailer lights so I think you should be ok for 0.070 Amp. Confusedalut:
Are you sure it doesn't read "Amp" rather than "mili-amp". :thumbsup:
  • vinny048
Cheers for that, when you remove the rear lights there is a warning label on the harness stating any connections must not exceed 10mA.
This is the camera I've bought
http://item.mobileweb.ebay.co.uk/viewite...0802246680
Can anyone point me in the direction of a relay?
Vinny
Found this in another thread.
http://www.berlingoforum.co.uk/showthrea...light=10ma
Still think you should be ok to connect direct.
Let's face it, you can fart more than 70ma. :whistle: :lol:
  • Diego Barrios
(27-10-2012, 09:10 PM)Rustscrat Wrote:  Hi, where abouts is the warning Confusedcratch:
(27-10-2012, 11:05 PM)Rustscrat Wrote:  Still think you should be ok to connect direct.
I know but I can't help but worry. :censored:
Scared ill fry the bsi
The scary thing is, you need a reversing camera on a berlingo! :eek:
(28-10-2012, 08:49 AM)steve valentine Wrote:  The scary thing is, you need a reversing camera on a berlingo! :eek:
It's mainly for reversing off my drive as there are cars parked on either side its difficult to see passing traffic on the road.
I've installed basic reversing sensors in the rear bumper of my van, working off the reversing light and had no problems whatsoever. These only have a consumption of 1.5 W which shall draw 125mA.
I'm with Rustcrat here as the pair of reversing lights will draw 3500mA so an extra 300, being less than 10% is pretty much negligible especially considering the 15A fuse.
Good Luck
Tubby
[-] The following 2 users say Thank You to Tubby for this post:
  • Rustscrat, vinny048
Thanks for all your replies, you've out my mind at rest
M59 unlocking itself
05-11-2025 04:06 PM
04-11-2025 09:48 PM
04-11-2025 09:15 PM
horn
03-11-2025 08:41 PM
How many miles
03-11-2025 08:12 PM
03-11-2025 08:08 PM
02-11-2025 07:53 PM
Boot liner with 7 seats
31-10-2025 07:57 PM
Last Post: Buki
31-10-2025 07:26 PM
31-10-2025 03:06 AM
» Replies: 40
