  • 6 Vote(s) - 3 Average
Steering column U/J
Has any one experience of replacing the universal joint at the bottom of the steering column where it connects with the steering rack.
Is this a main dealer part only, I can't see any listed on the web.
(31-10-2012, 09:15 PM)JohnM Wrote:  Has any one experience of replacing the universal joint at the bottom of the steering column where it connects with the steering rack.
Ask a dealer if it's available,& ask to see the picture(this is my sneaky way of seeing how it is fitted).It should be available & are generally straightforward,if time consuming,to fit.
Good luck & let us know how you get on.
  • JohnM
Part 4103H5 (number 2 in the daigram)
£54.73 inc
  • JohnM
Thanks for the replies £54 not too bad for a main dealer part. Frustratingly the grease in the U/J has dried out, I've temporarily sorted the problem by lubricating the joint, but I will have to bite the bullet and replace it. The parts diagram is a big help.
We're not too bad on here, we do try......
i agree
has any one actually done this job and managed to get the cab boot seal to go back into place propperly.
sounds like my engines in the cab atm and i get cold toes in the morning.
im one step away from tigersealing it in......although ill probably get it all over the carpet !
Thanks for the diagram coco, it was good timing for me as I'm looking at moving the steering column to the right if I can in an attempt to have the steering wheel centralised to my body, currently offset to the centre of the vehicle. I have gained some benefit from relocating the seats but need just that little bit more to finish the job.
Your diagram will save me stripping off the covers just to look.
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
