  • 5 Vote(s) - 2.8 Average
Rattle/Knock when switching off
I am a new berlingo owner (2008, Mk3 multispace 1.6HDi). Today I have noticed that when I switch the ignition off the engine make a knocking/rattling for a second as the engine stops. Anyone else had this problem
(01-11-2012, 04:29 PM)cascas Wrote:  I am a new berlingo owner (2008, Mk3 multispace). Today I have noticed that when I switch the ignition off the engine make a knocking/rattling for a second as the engine stops.
Is it petrol?which I suspect it is.If so let it idle for a second or two before switching off.NEVER blip the throttle before switchingoff.I cringe when I see that done.Try giving it a bit of hard work,it may be coking up & detonating.
If it's a diesel I can only suggest dripping injectors.Try a good fuel cleaner & a workout.
Diesel. Happened every time I started and switched off this afternoon - 6 - 7 times, but tonight when I went out with a torch and opened the bonnet it did not do it!!. Have checked the Engine cover, but all looks ok
(01-11-2012, 11:05 PM)cascas Wrote:  Diesel. Happened every time I started and switched off this afternoon - 6 - 7 times, but tonight when I went out with a torch and opened the bonnet it did not do it!!. Have checked the Engine cover, but all looks ok
Been quiet al day, and then started again. Mainly noticeable when engine is turned off. Lasts a second or two, and about 4-5 knocks as the engine winds down. As it happens, when the bonnet was opened it decides to behave again! Could it be a DMF issue?
Something resting against the bonnet , goes away when bonnet lifted?
Confusedcratch:
(03-11-2012, 04:42 PM)brodfather11 Wrote:  Something resting against the bonnet , goes away when bonnet lifted?
Confusedcratch:
After a bit more investigation, it only seems to occur when the engine is hot. No noise is heard when the bonnet is up outside of the car, but is heard by the person in the drivers seat. Seems to be on the drivers side, but cant pinpoint it. Any suggestions.
Brake problems again!
Yesterday 08:47 PM
CITROEN VIRTUAL SERVICE MANUAL ALL MODELS
18-06-2025 05:34 PM
» Replies: 33
P0691 P0693 cooling fan circuit problem
18-06-2025 07:32 AM
Does My Van Have A Tracker ?
Last Post: Mark604
17-06-2025 03:01 PM
Last Post: Cumbrian
15-06-2025 09:02 PM
14-06-2025 10:57 AM
» Replies: 36
Last Post: Vlad
12-06-2025 02:36 PM
11-06-2025 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
11-06-2025 10:33 AM
Nearside Headlamp bulb change
10-06-2025 01:59 PM
