  • 8 Vote(s) - 3 Average
Electric windows - how to lower without BSI?
Hi,
I need to refit a recently repaired BSI unit to my Berlingo (see the forum post about my Wet BSI saga which has just repeated itself).
Can someone advise as to how I can mechanically wind the driver's window down (the battery and BSI are currently disconnected)?
Due to paranoia and caution around the BSI reconnect-and-reboot, I want to follow this procedure to the letter.
Many thanks,
Tom
I don't know about a physical winding down of the window but can you not run a direct feed / earth from the battery to the output side of the window switch only ? Any old cable would do this as load is small.
The only way I can think of, and I replaced a broken mechanism recently, would be to take the door card off and take the glass out of the clamps that attach it to the winder. If you do do it very carefully, the glass is heavy and will drop to the bottom of the door. If Rustscrat approves I would go the direct feed route, however you have to be careful again that you are winding it the right way, also the drivers side goes through a control unit (which sits under the fuse box by the steering wheel) after the rocker switch and it might be better to bypass this too.
What about getting someone to sit in the drivers seat while you connect the battery then they can turn the side lights on to reboot.
The only reason to have the window down is so you can lean in and get to the switches.
:thumbsup:
[-] The following 2 users say Thank You to Rustscrat for this post:
  • ron, Wombat
(02-11-2012, 08:07 PM)Rustscrat Wrote:  What about getting someone to sit in the drivers seat while you connect the battery then they can turn the side lights on to reboot.
:thumbsup:
Confusedillyme: :lol::lol::lol:
Tongue
:thumbsup:
Doh! Of course. Thanks Rustscrat.
:S Confusedillyme:
:thumbsup:
:S Confusedillyme:
No worries, your welcome. There's been many a time I haven't seen the wood for the trees, So our lass says any way! Confusedillyme:
  • ron
Thanks Rustcrat,I was scratching my head about the window down thing.
  • Rustscrat
The other way of course is to have the door open and fool the system by holding in the door switch.
BSI was returned from BBA Reman today. Reconnected and booted as per the battery-reconnection protocol referenced in first post. My wife was happy to do the job of headlight and ignition switcher-onner, while I reconnected the battery and stood outside.
Result. Berlingo is back on the road again!
This time I put some packs of silica gel amongst the rats nest of wiring above the BSI. Also added sealant to interior of windscreen and thoroughly cleaned out leaves from below plastic drain/vent panels (under wipers). Let's hope the BSI stays dry next time we have a downpour.
Thanks again for all your posts of advice!
[-] The following 1 user says Thank You to Wombat for this post:
  • ron
eolys
Last Post: magoo1
Yesterday 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
