  • 6 Vote(s) - 3 Average
ELECTRIC TROUBLES
WENT TO GET IN VAN OTHER NIGHT KEY FOB NOT WORKING GOT IN VAN USING KEY, PUT KEY IN IGNITION AND EVERY LIGHT ON DASHBOARD CAME ON PLUS HEAD LIGHTS WHICH I COULD NOT TURN OFF FROM SWITCH, COULD NOT GET IMMOBILE OFF, TRIED TURNING ENGINE OVER BUT IT WAS AS IF BATTERY WAS FLAT,HAD TO GET A TOW HOME, OF COURSE IT WAS POURING WITH RAIN AT MOMENT VAN JUST SITTING ON DRIVE, ANY HELP PLEASE.
Modern electrics are beyond me, but if I had this problem I would disconnect the battery, then go back indoors for an hour and have a beer. I'd then reconnect the battery and see how it looked then. No doubt someone with more knowledge than me will be along shortly.
Good luck.
(03-11-2012, 04:51 PM)TOPDECS Wrote:  TRIED TURNING ENGINE OVER BUT IT WAS AS IF BATTERY WAS FLAT,
Have you checked the battery voltage yet? or did you try jumpstarting it?
I'd disconnect the battery, check the voltage, charge the battery if it needs it, then reconnect the battery (search on this froum for BSI reset precedure, basically the cars ecu might need resetting).
The only time something like this has happened to me was when a fuse had blown, once the fuse was replaced and the ecu reset it was fine.
The fact you mentioned it was pouring with rain makes me think that perhaps water has got into somewhere it shouldn't have and is causing problems.
Firstly, can you please stop typing in CAPITALS, as it very difficult to read, and in internet forum terms insinuates shouting! Thanks.
Secondly, if all the lights came on when you inserted the key, it would indicate a short in the system, as many of the circuits would normally be isolated through various switches, or circuits within the ECU.
I would locate the ECU and check to see if anything has got wet there. If it has, it may have shorted out the ECU, which will probably require replacing. If it doesnt appear that rain is the issue, then the next option is chasing the route of the main ignition wiring throughout the car to locate any chaffed, split or broken wiring.
(03-11-2012, 09:24 PM)LowLingo Wrote:  Firstly, can you please stop typing in CAPITALS, as it very difficult to read, and in internet forum terms insinuates shouting! Thanks.
Sorry for all the capital letters.
Had a dianostic check yesterday and the chap could not get areading he reckons the ecu has gone am going to have a chat with my Citron dealer tomorrow to see how much if it can be fixer, fingers crossed.
(03-11-2012, 05:52 PM)pidgeonpost Wrote:  Modern electrics are beyond me, but if I had this problem I would disconnect the battery, then go back indoors for an hour and have a beer. I'd then reconnect the battery and see how it looked then. No doubt someone with more knowledge than me will be along shortly.
Good luck.
Tried that still no different, thanks for reply
can the ECU be reset or is it a new one plus any idea how much?
Hi, Start with the basics.
Check that the battery is charged.
Check both main terminal connections and the chassis earth + the gearbox earth.
Check all the fuses in the BSI (as mentioned) + the engine bay fuse box.
Your engine should still turn over with the key. If it's not then there could be a problem with :
Your battery, starter motor or solenoid or the connections from your battery to s/motor etc or earths.
Let us know what the results are. :thumbsup:
Users browsing this thread: 3 Guest(s)
Yesterday 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
06-06-2026 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
