  • 6 Vote(s) - 1.83 Average
Removal of tray between front seats
Can anyone give guidance about removing the central tray, I have lifted the felt pad to find a couple of hex head screws and a nut inside a deep recess, this seems straightforward. The anticipated problem is that the handbrake is surrounded by an integrated rigid plastic moulding ....... this is the problem, any suggestions about removing this handbrake moulding?
Thanks in anticipation
From a quick look at my enterprise van (the bench-seat arrangement) the moulding is in two halves either side of the lever.
Try to lever them apart in an inconspicuous area and be prepared for broken clips.
Find out how much a new one is first!
What are you up to? - or shouldn't I be asking....
(05-11-2012, 05:08 PM)evdama Wrote:  From a quick look at my enterprise van (the bench-seat arrangement) the moulding is in two halves either side of the lever.
No problem in asking, hope to fit a 12volt socket, maybe the mini socket type depending on room, which will be wired to a constant live feed through a fused spur. Hopefully this will be a neat job.
U can take the plastic of the handbrake just pry it with a flat head screw driver done it my self a while ago pretty simple
Is yours a two piece or one piece moulding. if its a two piece then there should be four torx screws that you need to remove, after that your pull back the rear piece and lower the handbrake slightly to remove. refitting is the reverse procedure if my memory serves me well. But you shouldn't have much problems just remember to park on level ground and chock the wheels for safety.
don't touch the nut as this is the handbrake tensioner
i used this when i was changing my cigar lighter, was very useful.
.zip   ere.zip (Size: 86.95 KB / Downloads: 35)
hi. you also might have to release handbrake cable to give you more flexibility,...........cheers..............[Image: smile.png]
Timing belt change interval
Today 03:06 PM
» Replies: 19
B9 tailgate lock
20-04-2025 01:58 PM
Tie rod end bad almost every year
19-04-2025 10:56 AM
Water Leak Boot (tried a number of suggested fix...
19-04-2025 10:49 AM
AC Compressor Clutch
Last Post: tomhick024
18-04-2025 05:36 AM
Cruise control retrofit
17-04-2025 08:15 PM
Exhaust bracket
Last Post: timpascoe
17-04-2025 12:29 PM
Last Post: Mehal888
15-04-2025 12:57 PM
» Replies: 75
Washer Pump *Brand New unopened*
Last Post: Antdad
13-04-2025 05:47 AM
2.0 hdi clutch
Last Post: Martinez
13-04-2025 01:11 AM
