Low profile tyres.
Threads: 30
Thanks Received: 6 in 6 posts
Thanks Given: 123
Hi,
I've seen a set of 17" alloys with low profiles on.
What are your thoughts on low profs on a working van?
Are they OK or will I have problems??
Cheers,
MC
Threads: 28
Thanks Received: 68 in 50 posts
Thanks Given: 29
Wouldnt 17" be too big especially with weight in making it even lower and regarding the low profiles i had them on a previous car and the ride was shocking it felt like there was no suspension and everything rattled. But that is my opinion and maybe someone on here has some fitted already and could let you know.
Threads: 30
Thanks Given: 123
(07-11-2012, 10:35 AM)BerlingoHDI Wrote: Wouldnt 17" be too big especially with weight in making it even lower and regarding the low profiles i had them on a previous car and the ride was shocking it felt like there was no suspension and everything rattled. But that is my opinion and maybe someone on here has some fitted already and could let you know.
Ahh, I had thought with the added wheel size but the reduced tyre height that the ride height woudn't be altered at all, as the overall wheel+tyre diameter would be the same. Is that not the case?  illyme:
Threads: 28
Thanks Given: 29
(07-11-2012, 10:53 AM)Merlecollins Wrote: (07-11-2012, 10:35 AM)BerlingoHDI Wrote: Wouldnt 17" be too big especially with weight in making it even lower and regarding the low profiles i had them on a previous car and the ride was shocking it felt like there was no suspension and everything rattled. But that is my opinion and maybe someone on here has some fitted already and could let you know.
you could possibly be right although on mine the rear arches look smaller than the front but as i say the ride quality is compromised,
Threads: 20
Thanks Received: 60 in 52 posts
Thanks Given: 19
I had 17" alloys on the van for a while with 205/40 tyres with no problems (other than monster truck stance on standard suspension) only time I got rubbing on the rear arches was when I was carrying some bloody heavy ceramic floor tiles in the back! Weirdly I thought it rode better than when it had the standard 14's fitted lol.
Sent from my BlackBerry 9800 using Tapatalk
'04 Peugeot Partner HDi LX. Lows, Leaks and Wellers. Now matt grey and dent free
The following 1 user says Thank You to PeteA for this post:1 user says Thank You to PeteA for this post
• Merlecollins
Threads: 5
Thanks Received: 44 in 35 posts
Thanks Given: 4
07-11-2012, 01:59 PM
(This post was last modified: 07-11-2012, 02:01 PM by FeuxLingo.)
Low profile tyres will make negligible effect to the ride comfort. What usually affects it is when you also lower the suspension at the same time as fitting new wheels and tyres. If the suspension is of the cheaper variety, and not 'tuned' to the specific model of car/van, then the ride quality will change.
(07-11-2012, 10:35 AM)BerlingoHDI Wrote: Wouldnt 17" be too big especially with weight in making it even lower...
Wait, what?
How would the unsprung weight of a wheel affect the ride height of a vehicle?
:lol:
Threads: 30
Thanks Given: 123
(07-11-2012, 01:44 PM)PeteA Wrote: I had 17" alloys on the van for a while with 205/40 tyres with no problems (other than monster truck stance on standard suspension) only time I got rubbing on the rear arches was when I was carrying some bloody heavy ceramic floor tiles in the back! Weirdly I thought it rode better than when it had the standard 14's fitted lol.
Well PeteA you've just made my mind up for me.
I am a wall and floor tiler, so 17" are out the window for me...:lol:
Looks like i'll be searching for a set of 15's at the most
Threads: 5
Thanks Given: 4
(07-11-2012, 02:25 PM)Merlecollins Wrote: (07-11-2012, 01:44 PM)PeteA Wrote: I had 17" alloys on the van for a while with 205/40 tyres with no problems (other than monster truck stance on standard suspension) only time I got rubbing on the rear arches was when I was carrying some bloody heavy ceramic floor tiles in the back! Weirdly I thought it rode better than when it had the standard 14's fitted lol.
It all depends on rolling radius and offset. If the rolling radius are offset of 17" wheel and tyres is the same as the stock Berlingo wheel and tyre combo, then you'll have exactly the same clearances, therefore no rubbing issues any different to if you were running the stock wheels and tyres.
Threads: 30
Thanks Given: 123
(07-11-2012, 03:21 PM)LowLingo Wrote: (07-11-2012, 02:25 PM)Merlecollins Wrote: (07-11-2012, 01:44 PM)PeteA Wrote: I had 17" alloys on the van for a while with 205/40 tyres with no problems (other than monster truck stance on standard suspension) only time I got rubbing on the rear arches was when I was carrying some bloody heavy ceramic floor tiles in the back! Weirdly I thought it rode better than when it had the standard 14's fitted lol.
OK, so I suppose the next question I have is 'how do i find out the rolling radius of both stock and 17"'?:whistle:
Threads: 5
Thanks Given: 4
(07-11-2012, 03:26 PM)Merlecollins Wrote: (07-11-2012, 03:21 PM)LowLingo Wrote: (07-11-2012, 02:25 PM)Merlecollins Wrote: (07-11-2012, 01:44 PM)PeteA Wrote: I had 17" alloys on the van for a while with 205/40 tyres with no problems (other than monster truck stance on standard suspension) only time I got rubbing on the rear arches was when I was carrying some bloody heavy ceramic floor tiles in the back! Weirdly I thought it rode better than when it had the standard 14's fitted lol.
Input your stock, and proposed new wheels and tyre sizes into the following to compare.
http://www.willtheyfit.com
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
