  • 6 Vote(s) - 3.17 Average
Dickie Temparature Gauge.
Hi all,
Just wondering if anyone else has the same problem I am encountering Confusedcratch:
I have a 2003 2.0hDi.
Intermittently my 'STOP' light flashes on the dash, I get a chiming warning noise and the temp gauge goes up to max.... It doesn't seem to happen at any particular time or after I've done anything...after a short time it stops and goes back to normal.
There is plenty water in the engine and it is not overheating Confusedcratch:
Changing the temperature sender unit fixed it for me on my old 2.0 HDI, but have a look at this thread:
http://www.berlingoforum.co.uk/showthread.php?tid=3693
Tony
[-] The following 1 user says Thank You to tc_1 for this post:
  • Merlecollins
Hi, does this only happen when the engine is warm ?
Could be the thermostat getting slow to open.
Do the cooling fans come on when you get the stop light?
Check the connections on the sender.
let us know what you find. :thumbsup:
  • Merlecollins
(08-11-2012, 03:21 PM)Rustscrat Wrote:  Hi, does this only happen when the engine is warm ?
No, actually it has happened when I first turn the engine on from time to time.
I have located the green widget temperature sender unit that tc_1 has mentioned and think I will tackle that first to see if it helps :thumbsup:
A quick check of the cooling fans is, disconnect the plug on the sender and turn the ignition on.
Confusedalut:
  • Merlecollins
(08-11-2012, 05:00 PM)Rustscrat Wrote:  A quick check of the cooling fans is, disconnect the plug on the sender and turn the ignition on.
Confusedalut:
Fans are working OK, as I can hear them when I get out of the vanWink
Ok, in that case go for the temp sender as TC said. Confusedalut:
  • Merlecollins
(08-11-2012, 01:20 PM)tc_1 Wrote:  Changing the temperature sender unit fixed it for me on my old 2.0 HDI, but have a look at this thread:
Tony
Hi Tony, Does this look like the correct part?
http://www.ebay.co.uk/itm/Berlingo-2-0-H...5d35901b01
That looks like it. here is one at GSF, I got mine form Euro car parts:
http://www.gsfcarparts.com/929pc0560
let us know how you get on.
Tony
(09-11-2012, 05:12 PM)tc_1 Wrote:  That looks like it. here is one at GSF, I got mine form Euro car parts:
Tony
Will do, thanks again Tony.
Is there a part reference for the clip and 'O' ring?
Today 02:22 AM
removing front strut
Today 02:07 AM
Strut Top Mounts
Yesterday 07:58 PM
14-09-2026 09:27 PM
Rear seat belt breakage
14-09-2026 04:13 PM
12-09-2026 05:49 AM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
29-08-2026 08:39 PM
