Thanks Given: 1
Hi all,just got brand new van and hoping to get to know the in's and out's of it
Regards
Nick
Threads: 50
Thanks Received: 475 in 420 posts
Thanks Given: 743
Welcome....which one have you got??
Thanks Given: 1
Thank you,I got the 1.6 hdi 75 enterprise,first impressions are very good
Used o have a 1.9 scudo and it cost £105 to fill the tank
Just filled the berlingo £65
This thing will pay for it's self in fuel saved alone.
Threads: 80
Thanks Received: 372 in 315 posts
Thanks Given: 160
13
(08-11-2012, 06:24 PM)nikbuchanan Wrote: Thank you,I got the 1.6 hdi 75 enterprise,first impressions are very good
Welcome -good choice of van and forum.
Use the forum search when you can and see if you can get some piccies uploaded.
Ive got the same model and can easily get 60mpg.
First-off though dont allow the larger offside rear door close even slightly before the small offside one.They changed the latches from the earlier MK3 and you willl get a dent with very little effort.
Allow the engine to run a little while before touching the accelerator pedal , let the engine idle for a while before switching off and get the oil and filter changed before the service interval.
These three will help to minimise the turbo failure which has been a problem with some hdi engines in the past.
• nikbuchanan
