10-03-2011, 11:11 AM
Hi all, me again!
I now have a different problem with the glow plugs / glow plug relay. As prior my last post with starting problems the plugs were replaced before discovering the dealers hadn't realised the immobiliser had gone wrong. I have now by past the immobiliser and it has been running fine. Over the last couple of days first thing in the morning the glow plug light has come on and gone straight out again. The relay makes the click as it should do but wont stay open to heat the plugs. Once tapping it with a screw driver it started but that has been about it.
I have been down the breakers and brought a hand full of relays all of which have the same numbers on the top were the wiring diagram is and the PBT number is the same but the four digit number stamped on the same side as the PBT number is different.
Does anyone know if that is a problem or there could be any other reason for this to happen?
cratch:
