Hi, I have a 2003 2.0HDi Peugeot Partner (same thing innit!) and the horn only works with the ignition off and key removed! - is this caused by the Com2000 thingy or a bad contact somewhere (though if it works with ignition off and key removed I dont see how it can be a contacts issue?)
Please help as failed the MOT and I dont want to have to spend a fortune at a dealership!!
thanks
Threads: 17
Thanks Received: 117 in 92 posts
Thanks Given: 153
hi mate,
Has the previous owner or yourself fitted ANYTHING aftermarket? eg: phone kit/ steering controls??
If so:
Likely cause: the horn supply connected to the wrong fuse or on the key switch block.
Recheck both the horn AND the aftermarket item(s) wiring by starting from the business end of each and tracing it back through the fuse and switch to the power source.
You'll need: a 12V test lamp or a multimeter and
basic experience in car electric systems.
good luck.... let me know how you go....
Hi, Thanks for reply.
I have owned the vehicle for 4 years and there are no extras on it or aftermarket alarms etc. The horn will work occasionally when driving and was working daily last week after a long spell of same problem. I just got round to thinking it had sorted itself when heypresto its back to its faulty status again.
As I said earlier, it works EVERY time with the key out of the ignition i.e parked situation! - I love the car for its space and fuel economy but I have heard that the electrics can be pain in the **se!
Threads: 17
Thanks Given: 153
Is a tricky one....?
The testing procedures above can still be carried out though, if you feel confident.
If there are no remnants of aftermarket equipment, then hopefully you will track this down to a faulty connection..
Otherwise could well be the comm 2000 if it has not been replaced already......
Threads: 17
Thanks Given: 153
Depending on availability of Lexia diagnostics. This link may be of interest to you if you need to get through the MOT:
http://www.bba-reman.com/content.aspx?co...ot_process
thanks for the interest in my horn problem. I will probably have to go to a main dealer by the sounds of it. I did try a BSI reboot following a special procedure I found on the web and it made no difference. Horn connections must be good if i works with key out of ignition after switching off engine so reckon it must be this com2000 unit thing!
Threads: 5
Thanks Received: 5 in 5 posts
Thanks Given: 8
I have the same problem , the horn only works when the ignition is not on. Been told by an expert that its a bad earth problem and to clean the earth points up.
Multispace 1.9D Mystery Machine.
The following 1 user says Thank You to Pitman for this post:1 user says Thank You to Pitman for this post
• Cryian
