  • 3 Vote(s) - 2.67 Average
Wheel info help
Advice needed please. Will the C4 VTR 17" Alloy wheels fit a Berlingo multispace? i know the offset is different from the standard berlingo wheel but would a spacer allow these wheels to fit? or whats the largest and widest wheel that will fit without body modifications? Advice would be much appreciated.
Size of the wheel? Offset figure?
Hello ????
GENUINE C4 VTR Wheel, "17" Resolfen". i dont know what the offset is. ???
(10-11-2012, 08:45 PM)Gollycrush Wrote:  GENUINE C4 VTR Wheel, "17" Resolfen". i dont know what the offset is. ???
Without knowing the offset, it will be very hard to offer you advice.
Quick Google search tells me the C4 has a 25mm offset.
'04 Peugeot Partner HDi LX. Lows, Leaks and Wellers. Now matt grey and dent free Smile
[-] The following 1 user says Thank You to PeteA for this post:
  • Gollycrush
(10-11-2012, 10:48 PM)PeteA Wrote:  Quick Google search tells me the C4 has a 25mm offset.
Would a 20mm hubcentric spacer make up the difference in the offset of the original wheel at et15 to that of the resolfen et25 without any problems?
Have a look here:-
http://www.1010tires.com/WheelOffsetCalculator.asp
  • Gollycrush
(11-11-2012, 08:11 AM)Coco Wrote:  Have a look here:-
Has anyone fitted the resolfen 17" wheel to a Berlingo? or anything similar?
Use this to compare the proposed new alloy wheel and tyre combo to the stock wheels.
http://www.willtheyfit.com
Adjusting the offset is pointless without knowing the width of the wheel.
Coolant
Last Post: tomhick024
Yesterday 06:18 PM
SOLVED: P20F6 fault
Yesterday 08:28 AM
Leaking windscreen or aerial
15-04-2026 08:50 PM
