  • 8 Vote(s) - 3 Average
2.0 HDI (05) Radio/CD Intermittent fault
Hi Folks,
Some time back I had some mysterious elec problems with my van - sorted by the folks on here after BSI reset. All was well for some time until the Radio/CD has taken on a mind of its own - switching on and off at will - but always after I have tried to switch it on. It will work correctly for a few days, then lose all memory and bass/treble settings accompanied by warning beeps. I noticed also that sometimes the radio illumination will go off and on even when I'm not using it. I have removed the unit and used dielectric grease on the terminal blocks after cleaning to no avail. Does anyone repair these radios, or if I replace it with another make can I still have all the stalk facilities and display info?
These radios require a permanent supply even when switched off.
What you're experiencing sounds like a intermittent connection on either the red or
yellow wires (whichever is the permanent voltage supply). Follow each both back to it's fuse
and check for loose/corroded connections. HTH
(17-11-2012, 04:15 PM)OlJeffers Wrote:  These radios require a permanent supply even when switched off.
Many thanks for the reply and the info - I'll check it out as soon as poss. It sleeps out in the salty atmosphere here in Orkney so corrosion on terminals is certainly a route to go down. I'll come back with any findings.
Regards,
Ian
Still no joy with this very intermittent radio problem. I've done a 1500 mile round trip over Christmas/New Year after checking wiring/connector corrosion and it was fine for some of the trip, then on/off as before. Later on the way North it was fine and then at home it played up again. Now OK again. Anyway I now have a Vscan simple scan tool OBD2/EOBD compatible which works fine on my '99 XJ8 Jag but refuses to communicate with the definitely compliant late 2005 2.0 HDI Blingo. Anyone got any ideas? I thought I would scan it to see if the radio/display fault threw up a code.
That intermittent behaviour has to be an intermittent connection.
OBD tools will not help with the audio system.
Like O.J. I would look for a poor connection, either supply or earth
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
