  • 5 Vote(s) - 2.6 Average
Fitting New Tie Down Rings/Loops
I want to fit some new tie down rings, anyone added additional rings before?
No -but the obvious is big plates underneath-screwfix /builders merchants will have galvanised stuff ready made-then underseal when your done.
Is 6 not enough?
My guests never manage to wriggle free.
You can never have enough. ha!
Well actually I have a plywood floor currently and was consider fixing some to that just to strap a few things down so they don't slide around...
How about these then-you would still need washers on the underside to stop the fixings pulling through the ply with all the struggling.
http://www.screwfix.com/p/hardware-solut...d-m8/89565
(18-11-2012, 05:50 PM)evdama Wrote:  How about these then-you would still need washers on the underside to stop the fixings pulling through the ply with all the struggling.
Not bad idea... I would need to find some fairly flat bolt heads... Hunt is on...
Roofing bolts??
(18-11-2012, 05:55 PM)OlJeffers Wrote:  Roofing bolts??
Yes perfect or coach bolts-but make sure they have the square section under the head.
You drill a smaller size hole then bash them in from under the ply.The square bit then bites into the ply and stops the turning when you tighten the nut.
[Image: 2yjy8ar.jpg]
Sorted! I fitted two additional Tie down rings today. :-)
Drilled through the floor and bolted properly either side. Works a treat.
Leaking windscreen or aerial
15-04-2026 08:50 PM
Apple Carplay
02-04-2026 01:26 PM
