Threads: 2
Thanks Given: 2
hi all i bought a 1999 belingo 19d the clutch is hard to press and it is hard to pull away it jumps forward i drive a work belingo and the clutch seems loose compaired to mine.It has just started to make a clicking noise when i push the pedal down and sometimes it wont go into gear if i pump the clutch a few times it works fine has anybody any ideas what it can be thanks
Threads: 23
Thanks Received: 24 in 15 posts
Thanks Given: 11
18-11-2012, 07:05 PM
(This post was last modified: 18-11-2012, 07:08 PM by Husqyman.)
Auto adjust mechanism up the creek ? pumping should make no change on a cable clutch, what's the mileage?, the jumping forward does sound like the clutch has had it though.
The following 1 user says Thank You to Husqyman for this post:1 user says Thank You to Husqyman for this post
• dbutch
Threads: 2
Thanks Given: 2
thanks for the help. Theres 180000 on the clock so i was thinking it could be on its way out i was hoping it wasnt though.so is the auto adjust mechanism on the cable or is it a separate part i dont no much about these things thats all.thanks again
Threads: 50
Thanks Given: 743
Change the cable first! If it's sticking then you'd get pretty much what you're now experiencing.
I believe that there is a thread somewhere on this forum dealing with the cable and how it may be re-routed
so it works better.
