Hi ya, just purchased a berlingo 2.0 hdi van on a y plate. When I got it drove it home fine without any issues, today took it to work put £20 worth of fuel in just over quarter on gauge drove few miles gauge drops loads. Got to work ok didn't think to much about it till went out again and pulling onto motorway building revs up engine management light comes on and shuts down engine.
Restarts fine drives ok till get to around 3000 rpm then does same. Went to mates garage fault codes p1517 and p1112 he told me they were coded anti start operation and fuel rail pressure?
Any one with any info on problem and fix would be great
Thanks ben
Any ideas or solutions?
Threads: 50
Thanks Given: 743
21-11-2012, 06:11 PM
(This post was last modified: 21-11-2012, 06:12 PM by Ol'Jeffers.)
P1517 CODED ANTI-START OPERATION
P1112 FUEL RAIL PRESSURE
The first code I believe is the ECU's response to the second code in not allowing the engine to start.
The second code could indicate anything in the fuel line from a blocked or worn out injector to a failing
fuel or injector pump.
I'm no expert but I would take the car to a competent independent garage for a full check
and measurement of the fuel rail pressure plus an injector check.
Maybe one of our experts will be along later to give you more detailed/accurate advice.
Oh! Welcome to 'our' place!
Many thanks for the reply,
I wasn't sure if there was a common fault with them that someone may know. I have booked it for a full service so will see if fuel filter helps first if not will get get checked whilst at garage.
Any other ideas etc would be great.
Thanks again ben
Threads: 50
Thanks Given: 743
21-11-2012, 07:19 PM
(This post was last modified: 21-11-2012, 07:20 PM by Ol'Jeffers.)
No problem, Ben. What mileage does the van have?
A lot lol traveled to moon and back few times.
216k.
