  • 3 Vote(s) - 2.33 Average
window fault
Wink
Need some pointers please,wound window down tday and it dropped quite a bit manged to push back in place,I gather cable operated, of some description,havent got the door aprt yet.Is it easy fix,also when doing cam belt is it advisable to do water pump,engine has done 70k?
any help cheers murf.
Never done a cambelt on berlingo. (Haven't got book in front of me.)
Only on a Golf MK5, but yes if changing cambelt always change waterpump too as you don't want to have to remove cambelt just to change waterpump in future.
The widow winder arrangement is a amalgamation of nylon pulleys and cables which wear the nylon pulleys out. best visit a scrappie and change the whole assembly rather than try to repair. Sometimes the window guide bracket which hold the window glass guide in place rust away/break and the glass drops out.
I personally woundnt change the water pump unless noisey or it didnt feel right but I take the chance of it lasting another 70k.
Not worth changing the cam belt without changing the water pump at
the same time. IMHO. Likewise if the water pump fails you may as well
fit a new cam belt while you have the whole thing apart.
cheers chaps,going to change water pump and belt at same time,any special tools need for cam belt change,also anypointers where to go shopping for parts as been on net and parts vary in price.
cheers murf.
Rattling calipers
Yesterday 05:36 PM
eolys
Last Post: magoo1
15-05-2026 06:02 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
