  • 9 Vote(s) - 2.11 Average
Headlight Bulbs
Hi
Has any one upgraded Mk1 headlight bulbs, got one blown so thought good excuse to find better & brighter. headlights on my 807 well good and very white/blue light don't know what they are though. loads on ebay anyone tried them?
'If You're Not Living On The Edge, You're Taking Up Too Much Room.'
Founder Member: The Bad Parent Club!
(22-11-2012, 10:36 PM)terryd999 Wrote:  Hi
Get Osram Nightbreaker Plus :thumbsup: Superb :thumbsup:
http://www.ebay.co.uk/itm/300817405177?s...1438.l2648
Big thankyou to Merlecollins for the ebay link gonna order them in a minute, they look good and being Osram should last.
All I need now for night driving is some 20 year younger eyes!
How do I get my Mrs to respond as quick as you lot?
[-] The following 1 user says Thank You to terryd999 for this post:
  • Merlecollins
(22-11-2012, 10:54 PM)terryd999 Wrote:  Big thankyou to Merlecollins for the ebay link gonna order them in a minute, they look good and being Osram should last.
Just make sure that that link is OK for a MK1 as I have a MK2 and that was the link I used. :thumbsup:
I'm pretty certain (and someone else may confirm) that the bulb fitments are the same on both vans anyway, but would be happier if you made sure Wink
[-] The following 1 user says Thank You to Merlecollins for this post:
  • terryd999
H4 is what I remember buying for mine and Osram Night Breaker from Autobulbs direct,
http://www.autobulbsdirect.co.uk/?source...teid=63107
  • terryd999
Reports say the latest from Osram, the Nightbteaker + is even better.
[-] The following 1 user says Thank You to jericlin for this post:
  • terryd999
Nightbreaker Plus are nice looking, very bright bulbs, but...
They DON'T last very long!
Mine did about 9 months, and that wasn't through the winter.
Others on here have had similar problems.
[-] The following 1 user says Thank You to j90xxx for this post:
  • terryd999
Mine lasted 18 months but l have my lights turn on whenever I start the car.
Sent from my HTC Desire HD using Tapatalk 2
[-] The following 1 user says Thank You to 3rensho for this post:
  • terryd999
Just get some 100W generic 'ultra white xenon' bulbs from eBay, I've used the companies Redline and Xenons_UK [actually the same trader] extensively over the years fitting their bulbs to my cars without issue and with good longevity.
http://www.ebay.co.uk/itm/Citroen-100W-S...43aca8c582
Although the new up and coming technology is HOD bulbs [not to be confised to HID]. These are standard fit, don't require ignitors or ballast resistors, and are MOT compliant, unlike some HID kits. Not cheap though!
http://www.ebay.co.uk/itm/HOD-12Volt-Sup...337df6bb57
Nightbreaker Plus last longer than the original Nightbreaker, but still only 150 - 250 hours.
Had some 'ordinary' standard Ring Automotive headlight bulbs in my Clio that lasted about 6 years.
Osram won't last as long due to their properties and construction, you don't get the bright white light and longevity, it's a compromise.
(23-11-2012, 10:10 AM)LowLingo Wrote:  Just get some 100W generic 'ultra white xenon' bulbs from eBay, I've used the companies Redline and Xenons_UK [actually the same trader] extensively over the years fitting their bulbs to my cars without issue and with good longevity.
Will the 100w bulbs create any wiring/fuse/relay issues, as they will draw 8+ amps as opposed to a 'standard' bulb which draws about 4.5 amps?
Just thinking of the fragile French electrics. Confusedcratch:
Coolant
Last Post: tomhick024
Yesterday 06:18 PM
SOLVED: P20F6 fault
Yesterday 08:28 AM
Leaking windscreen or aerial
15-04-2026 08:50 PM
