  • 3 Vote(s) - 1.33 Average
Ext. temp and elec. windows
Hi, I`ve recently fitted a trip computer from a Citroen C8 to my 2006 2.0HDI Partner van (wish I hadn`t as it shows shes only doing 34/35mpgSad) but I`ve no exterior temp sensor, I was just wondering if anyone knows which pins from the door connector work the sensor?
I also wanted to add electric windows but can`t get any power to the switch, does it all feed from the BSI or should it have a window ecu like the mk1s?
(I have activated the window option in the BSI)
Cheers
Try a search - these topics have been covered before, the temp sensor very recently.
Don't forget to let us know how you get on as it might help others..................
  • jericlin
In the absence of anybody with more knowledge / info then me, and most will know more than me you could start by seeing if the door connectors are fully populated with pins and sockets ( Door side and car side ) ?
Count to see how many harness wires car side there are for both passenger door and drivers door. Count to see how many wires there are door side. if they match there is no harness connection ( assuming all door wires can be seen to go somewhere useful ), if they don't, you may be in luck, but then the car side of the harness may have wires for windows, electric adjust mirror, heated mirror ? etc
( I have't actually visually looked at these connectors inside their covers inside the door / behind A post trim yet so unless others can shed more light it's suck it and see )
Where in UK are you ?
Apologies for not searching first, I should now be able to sort the temp. sensor so jsut need to work out the windows now.
Cheers
Apple Carplay
02-04-2026 01:26 PM
Last Post: Transmit
02-04-2026 11:21 AM
