  • 5 Vote(s) - 3.4 Average
New Member
Hello
Just brought a Blue 03 Multi-space Forte with genuine low mileage locally & judging by a lot of examples I have seen over the last few weeks I would hope to get plenty more miles out of it yet.
Just browsing Forums for some advice on Handbrake adjustment.
Hi & welcome.Before you adjust the cable,if you have more than 5or6 notches,Remove the rear drums & make sure all is free & clean.Manually adjust 2 or 3 notches at a time,refitting the drum each time to check you haven't overdone it.Aim for light scuffing sound with NO drag on drum.
Before doing the other side,check the handbrake has not tightened up to less than 5 notches,this will give you enough slack to do the other side.
When all is done adj H/brake to 4-6 notches.Good luck & let us know how it goes.PS remove wear ridge from drums otherwise you will not get full adjustment.
FK Lowering kit actual drop
Last Post: dumdum
Today 12:46 PM
Lowering fun
Last Post: northroadycles
Today 11:12 AM
Plug phone into stereo?
Last Post: LukeLog
Today 10:27 AM
Modutop Door Hinges - Cable tie repair
Last Post: ghost123uk
Today 09:14 AM
Last Post: ffrenchie
Today 09:00 AM
» Replies: 627
How Often Does AC Need Re-Gassing?
Last Post: cancunia
Today 08:51 AM
» Replies: 18
Loose connectors under dash
Today 07:18 AM
How did the Berlingo get it's name ?
Last Post: hawaiianblue
Yesterday 05:30 PM
Full 1.9D Van Spares
Last Post: TONX
Yesterday 04:45 PM
new vehicle
Yesterday 02:51 PM
