  • 11 Vote(s) - 2.27 Average
[Engine] Cold Start Adjustment
I'm trying to get the cold start on my 1.9 DW8 working properly. It was adjusted so that the engine was running at 1100 rpm. The knurled cable adjuster is pretty much rusted up tight and when I try to turn it the bracket starts to bend. I slackened off the nipple and put some slack into the cable. Now the cold start doesn't seemto work. It starts and idles at about 750 rpm picking up to 800 when the engine is warm.
How much slack shoud be in the cable and where does it go to? What is at the other end of the cable to pull it to make the cold start work?
Malc
Stupid computer!
When the engine is cold there shoud not be any slack. When it warms up the thermostatic sensor located in the cooling system expands, the cable slackens and reduces the idle speed. My (xud) sensor is located in the thermostat housing. I think ? that yours (dw) is either in the fuel filter housing or the thermostat area. It dosen't seem to be working, try adjusting it when cold. They can be replaced.
Confusedtudy:
  • crickleymal
Thanks. The cable was tight at all times before I fiddled and the idle speed never varied from 1100rpm.
Malc
Stupid computer!
So I managed to unfreeze the cable adjustment and adjusted it when the engine was just about cold for 1100rpm. The today (it's quite cold) I start the engine and it idles at 800 rpm. When I get to work 35 miles later it's idling at 1100 rpm. So the bloody thing is working backwards. Help!!
Does anyone know of a Citroen/Peugeot specialist in Gloucester?
Malc
Stupid computer!
This any use Mal ??
.pdf   Injection pump adjustment.pdf (Size: 43.61 KB / Downloads: 169)
Confusedalut:
[-] The following 3 users say Thank You to Rustscrat for this post:
  • brodfather11, Ol'Jeffers, ron
That's great. Thanks very much
Malc
Stupid computer!
This must be a fairly common failure. I got the cold start mechanism out of a scrapped Berlingo and it doesn't move either. I stuck the temperature sensor in hot water for 10 minutes and the cable didn't move. Then I stuck it in the freezer for half an hour and it still didn't move.
Does anyone know the part number so I can order a new one please?
Malc
Stupid computer!
Not a problem for the part Number Malc, if you could PM me your Vin No. I can get an accurate match. :thumbsup:
You have a PM.
Malc
Stupid computer!
I've just seen the cost of one on Ebay. Feckity, feckity, feck £235!!!!. No wonder they don't get repaired. Maybe I'll fit a choke cable.
Malc
Stupid computer!
1.6hdi starting problem
Yesterday 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
