Threads: 50
Thanks Given: 743
29-11-2012, 06:36 PM
(This post was last modified: 29-11-2012, 07:41 PM by Ol'Jeffers.)
You shouldn't need to check! They should be there if there's a space for them.
I can't believe that good ol' Citroen would be so tight that they expect
you to........actually maybe they would!
Thanks Received: 2 in 1 posts
French cars have such bad electrics they probably used the spare fuses so they could drive it out the factory! :brickwall:
Threads: 81
Thanks Received: 396 in 339 posts
Thanks Given: 166
21
(13-12-2012, 11:06 PM)a135hnr Wrote: French cars have such bad electrics they probably used the spare fuses so they could drive it out the factory! :brickwall:
Probably fizzed a few out on the drawing board first....
• whitebus
Any idea where the fuse pliers should be? Can't find mine ( car less than a year old!)
Threads: 81
Thanks Given: 166
21
My 2012 didnt have them but I had the
ones out of my 2010 as a souvenier.....
