01-12-2012, 06:31 PM
Hi Everyone - Newbie question??
Had our Berlingo for a month now and am gradually sorting it to what I want.
It's an 55 plate M59 Desire 1.6HDi with the 9HX diesel (no DPF).
Having a problem fitting Cruise Control - stalk installed and enabled in BSI ok, engine ECU enabled for CC ok.
Lexia showing stalk switches operating ok, brake switch operating ok but Clutch Switch active permanently?
Can see (just) the small black switch above clutch pedal operated by a blue cam around the pivot (via mirror and torch). Can see the switch moving in-out as clutch pedal is pressed but Lexia shows the switch always active!
Illustration below is from Citroen pedal bracket info for Vin but the space in the LH bracket where the arrow points to the clutch switch mounting point, mine is solid metal (no access). Switch is between pedal mounts and above pivot.
Has anyone found a way to access the clutch switch to check or change it?
Doesn't seem possible from below without removing brake and clutch masters and pedal unit!!!
Not accessible from above by removing instruments.
Anyone found the way to get at the clutch switch??
cratch:
cratch:
