  • 5 Vote(s) - 2.8 Average
Squeeling Brakes... :-(
Just wondered if anyone has had this problem?Confusedcratch:
When slowing down or stopping my brakes sound akin to a double decker bus stopping....:S
I've had it into the garage and they say the pads are fine..
Is this common on MK2's?
If so is there a remedy?Rolleyes
My Mk2 does it a little bit too, I checked the discs and pads at the front and they were fine, plenty of copperslip on the back of the pads.
I don't know what it is, maybe the rear brakes?
had this problem too but didnt get round to trying the fix I knew from my motorcycling days. Which was to file a bigger chamfer (how do you spell that?) on the leading edge of the brake shoes. As the shoe wears the factory applied one disappears making a sharp edge which bites into the drum making it squeal. Might be wrong but it is worth a try maybe? It worked on my Kawasaki.
[-] The following 1 user says Thank You to mrbritse for this post:
  • ron
(02-12-2012, 09:41 AM)Merlecollins Wrote:  Just wondered if anyone has had this problem?Confusedcratch:
I had a new 2.0Hdi in 2003 and it had the same problem all the time I had it. It was never loud enough to be annoying just in the background. I had all the brakes off in the end and never found the cause, plenty of Copaslip and a work with a file made no change. I had the 'feeling' that it was only the rear brakes that squealed. They all worked 100% so in the end I gave up. Yours is the first time I have seen reference to this noise. I thought it was just me before.
Mine have done it ever since I got my 'lingo and have had brakes checked and they still do it, so I just live with it now.
Mine do it also. HOwever I need new discs so I'm hoping when I get round to doing them it'll solve the squeal. It's quite obtrusive on mine
Malc
Stupid computer!
I like the brakes to squeal, it keeps the pedestrians on their toes Big Grin
Interesting. If you're light on your brakes the pads can become glazed and squeal. A few false emergency stops breaks the glaze. I tend to brake lightly and our Bingo squealeth not. On t'other hand our Passat squeals like a pig at the first brake usage but never again.
[-] The following 1 user says Thank You to pidgeonpost for this post:
  • Merlecollins
MC listen . . . ssshhhhhh can you hear that . . . . ? no ? that's my brakes working :thumbsup: All joking aside I've never had a murmur from mine in 3 years even when dreadfully (nearly) overladen :whistle: niether has any Blingo (van) owner I know complained of such , only me 2 penneth . . .
If the pads are fine,champfered & copaslipped,then deglaze the rear shoes,dedust & lube(lightly) backplate pads & champfer the leading lining edges.If there is a wear ridge on the drum,remove it.
Diagbox 7.57 download
Today 09:13 PM
Today 05:26 PM
Air filter box removal
Last Post: Harrythephot
Yesterday 11:03 PM
Berlingo undertray
Yesterday 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
