Threads: 50
Thanks Given: 743
TBH I think I'd just tuck that plug away behind the dash. The extra fuses associated
with it will do no harm and if you can identify them the plug could possibly be used for
other ancilliary equipment in the future.
Threads: 50
Thanks Given: 743
Ummmm......you may have to partially remove the centre console.
The Torx screw in the picture right behind the plug may be a starting point.
Threads: 50
Thanks Given: 743
I think that is the right way to go for now as you have a better chance of not damaging anything.
If you were to cut off the plug you'd have to trace all the wires back to their sources before you did anything including
using the car!
Tracing the wiring using your multimeter is something you can be doing anyway without removing the plug, but the problem comes when you discover one or more share fuses with other circuits. If you give Rustscrat your VIN no. via PM he may be able to find the fuse and wiring diagram for your vehicle.
Threads: 81
Thanks Received: 396 in 339 posts
Thanks Given: 165
20
With multiplug connectors there is sometimes a 'tab' on each contct pin -a precision screwdriver or such like can be used to press in the tab and release the pin from the plastic block.
You would then be able to pull the wire through and put the pins back in afterwards
• Merlecollins
Threads: 81
Thanks Given: 165
20
Oh yes.
The big inline fuse holders in the 3rd picture dont look like PSA Group tack.
I think if you took the fuses out you may find the refridgeration circuit would be deadened.
Stick a multimeter in the connector before and after to see .
• Merlecollins
Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
Agree with the above.
Those 2 fuse holders in the 3rd pic shouldn't be there, although mine has one for the (now removed) flashing beacon.
See if any of the pins have 12v, then remove the 'extra' fuses in turn and see what happens.
As with all electrical work; disconnect battery first. :thumbsup:
