Threads: 2
Thanks Given: 3
hi i have a 54 plate 1.9d van and it has started with a rattle when the clutch is pressed but it is fine when when in gear and moving. there is no power loss or slip that i notice. i just wandered if it could be the thrust bearing and if so will it need doing now or could it wait and if not is it a easy clutch to fit
Threads: 20
Thanks Given: 2,126
18
It sounds like the release bearing.If left you can bet it will fail at the worst possible time.Changing the clutch is a typical front drive job.When you do it,change the gear oil as well.
Strawberry flavoured windows
The following 1 user says Thank You to ron for this post:1 user says Thank You to ron for this post
• janine
Threads: 50
Thanks Given: 743
If you're going to replace the bearing you may as well do the clutch while you're
in there. Try not to use a Valeo OEM bearing! They really are awful...note the size
and get a decent one in there. There are a few manufacturers including Quinton Hazell
and LUK.
Threads: 2
Thanks Given: 3
[quote='ron' pid='31684' dateline='1354484918']
[/quote
thanks for that i am going to replace the lot at the weekend. is there a specific oil to put in the gearbox and what amount does it take
Threads: 50
Thanks Given: 743
Not sure on the quantity but it's specified as EP75w90 semi synth.
