  • 6 Vote(s) - 2.17 Average
Reset remote key after battery change for MK1
My Keyfob does not seem to do anything, I have been searching for how to re sync it to the car!
I thied this:
Switch ignition on & wait for immobiliser LED (if fitted) to go out
(it goes out very quick about 0.5 of a second!)
Press lock button on key. LED should illuminate for 0.5 seconds.
Switch ignition off.
Is this right?
Is the something else I can try?
Don't really want to look at the com2000 module central control (maybe with a schematic!), if the are things to try before hand Smile
When I push the button on the key fob, the red light on it, comes on for halve a second.
This is what the key looks like!
[Image: voss50.jpg]
Hi, looking at the switch on your fob, it looks like it's seen better days as it seems convex. I know you said it's working but sometimes these small switches have 2 contacts.
Have a read of this, section 4. Confusedalut:
.pdf   Key fob syncing.pdf (Size: 12.49 KB / Downloads: 59)
[-] The following 3 users say Thank You to Rustscrat for this post:
  • dougienisbet, max, whitebus
I checked the switch and all contacts seem fine, looking at the key hole of the ignition it shows: St, A,- ,M, D. so I wonder if it is a different system, because the instruction say: Put the HF key to be synchronised in position "ignition +"
Granted it's only a bit of plastic in front!.
Any way I tried them all and no luck, so far.
Thank you for the document anyway Smile
[Image: 24w7f3o.jpg]
(03-12-2012, 05:08 PM)Rustscrat Wrote:  Hi, looking at the switch on your fob, it looks like it's seen better days as it seems convex. I know you said it's working but sometimes these small switches have 2 contacts.
valeo alternator CL15 rebuild
Yesterday 07:08 PM
Unusual Braking Problem
Yesterday 06:33 PM
Yesterday 06:19 PM
oil Sump
Yesterday 06:18 PM
5 x 18" wheels suit B9
Last Post: raymondinio
Yesterday 04:34 PM
M59 1.4 Petrol question
14-03-2025 10:48 PM
14-03-2025 09:29 PM
» Replies: 27
14-03-2025 09:08 AM
Insurance Shocker !!!
14-03-2025 09:04 AM
13-03-2025 08:09 PM
