BSI?
Threads: 9
Thanks Received: 1 in 1 posts
Thanks Given: 2
I have a Citroen Berlingo this has been my fav van so far, the problem im getting is there are no lights on dashboard only oil light and airbag light. here is the story from start to finish.
Everything was fine until the battery light came on while i was driving, i disconnected the battery and done a visual check and found nothing, i then reconnected the battery and there was no lights on the dashboard and no gadges etc, after a few minutes everything came back on but the battery light was still on.
the next day i removed the alternator and changed the brushes and reconnected everything and got the same fault again (nothing on the dash) but battery voltage was 14V. after about 3 hours everything came back and the battery light was off and charging at 14V. The next day it was really cold and had a bit of trouble starting the engine and took about 20 seconds of cranking to get it to start, but all the cranking drained the battery and the clocks went off again but this time never returned.
I tried a BSI reset but that did nothing, I took it to a repair garage and they plugged a computer in to it and reset it and everything came back to normal again, they drove it around the corner and the BS|I unit started smoking and the wipers where on continuous and all the clocks went off "AGAIN" .
Later that day I got it home with wipers on full, Removed the BSI unit and tried to start it, It started fine wipers where off and wouldnt work (obviously) after a bit of searching on google i found out the immobiliser is part of the ECU and nothing to do with the BSI because it was built before 2002. I found a second hand BSI unit and fitted that and still the clocks dont work. because the battery was flat i havent tried anything else.
Here is a list of things that didnt work when the clocks where off.
Speedometer, rev counter, fuel gauge, indicators worked but didnt make a clicking noise, time, distance, Heater plug light (didnt check plugs)
from what i can remember that was all. Thanks for reading all this and i look forward to some feedback,
p.S it's a berlingo W REG
Threads: 50
Thanks Given: 743
I'd get the original BSI repaired. (BBA Re-Man in Rochester.)
Don't know much about the Mk1 but if it's similar to the Mk2
then Lexia is needed to get the new BSI to communicate with the ECU.
There's bound to be someone else along who knows more about the Mk1
BSI .
Threads: 5
Thanks Given: 2
Hello,
I have the same problem together with couple of more, just have not taken it to garage yet, but will update when i next get paid that is lol
Threads: 18
Thanks Received: 468 in 294 posts
Thanks Given: 211
(03-12-2012, 11:21 PM)daz3nt Wrote: I have a Citroen Berlingo this has been my fav van so far, the problem im getting is there are no lights on dashboard only oil light and airbag light. here is the story from start to finish.
Hi, If you can P/Mail me your Vin No. I'll have a dig through the drawings. :thumbsup:
2006 2.0hdi 600 with bench seat.
Threads: 9
Thanks Given: 2
[/quote]
Thanks, I will find the vin in the morning and pm you, thank you very very very much. really is the wrong time of year to buy a new van
Threads: 9
Thanks Given: 2
OK, quick question, I have a lexia cable with software, a second hand BSI (because the old one caught on fire) is there a way with these two things to disable the immobiliser without cutting the shield off of the injector pump? again its an old mk1 berlingo 1999? please help my business was failing before this but is now even worse without a van.
Threads: 18
Thanks Given: 211
Do you know why it caught fire.  cratch:
Threads: 9
Thanks Given: 2
(09-12-2012, 12:39 PM)Rustscrat Wrote: Do you know why it caught fire. cratch:
not a clue, got a hunch that there may be a problem with the instrument panel, but not sure. I have the lexia plugged in but can change anything without the code which i cant get, been looking around and found i need an ad600 code calculator, any ideas?
Threads: 18
Thanks Given: 211
This might be a long shot but have you tried "03114". :thumbsup:
Threads: 9
Thanks Given: 2
(09-12-2012, 04:09 PM)Rustscrat Wrote: This might be a long shot but have you tried "03114". :thumbsup:
Thanks for your reply but its asking for a four digit code. Also says underneath letters O and I are not used.
Today 06:32 AM
Clocks dropping out
Last Post: Micklew
Yesterday 09:29 PM
air con
Last Post: magoo1
Yesterday 04:56 PM
triangle light
Last Post: Buki
Yesterday 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
