  • 6 Vote(s) - 2.5 Average
OIL IN INLET MANIFOLD
I HAVE A 1999 BERLINGO 1.9D, AND RECENTLY IVE HAD POOR STARTING, SO CHECKED THE GLOW PLUGS, THEY ARE FINE, BUT FOUND THEM COVERED IN OIL, LOADS OF OIL IN THE INLET MANIFOLD ASWELL, [/size][/font]ANY IDEAS? CHEERS
Just a thought, as I have only ever had motorcycle engines apart myself;
Overfilled engine oil or pump malfunction ? - crankcases are often vented through the air cleaner.
(04-12-2012, 05:57 PM)Athers 85 Wrote:  I HAVE A 1999 BERLINGO 1.9D, AND RECENTLY IVE HAD POOR STARTING, SO CHECKED THE GLOW PLUGS, THEY ARE FINE, BUT FOUND THEM COVERED IN OIL, LOADS OF OIL IN THE INLET MANIFOLD ASWELL, [/size][/font]ANY IDEAS? CHEERS
If it's like a tarry sludge,check crankcase breather is clear.It can also be cheap fuel/slow driving.
There is a special cleaner to use,but scrape the thick stuff out 1st.
Same problem, found it when i tried to change glow plugs cos of bad starting! found that the EGR valve was totally gunked up. I cleaned it all out of Valve and both inletmanifolds, metal and plastic with repeated dosing with degreaser and a brush, when back together it made a major difference to my performance and it now starts alot easier. I think its a lot to do with it reusing exhaust gas to cut do emisions. several posts on here about blocking the EGR pipie from Exhaust, might cut down build up in future.
Let us know how you get on
'If You're Not Living On The Edge, You're Taking Up Too Much Room.'
Founder Member: The Bad Parent Club!
2011 B9 DPF warning light
Yesterday 11:52 PM
Fuel Gauge trouble
Last Post: Pricklybuzzz
Yesterday 11:48 PM
Hello
Yesterday 11:43 PM
Any advice regarding boot carpets being wet!?
Yesterday 05:50 PM
» Replies: 21
Yesterday 10:53 AM
Frequent DPF REGEN's
17-01-2025 08:43 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
17-01-2025 02:29 PM
Power flex anti roll bar bushes
Last Post: NANO_Vigo
17-01-2025 10:54 AM
Power flex lower wishbone bushes
Last Post: AD246
17-01-2025 08:54 AM
How to change your username
Last Post: Mike
16-01-2025 11:04 PM
